Hinge Pin Sleeve
bmckinney10
My aileron hinges were getting a little loose so I started installing the Teflon lined hinge pins as noted in the CP for my VariEze.  I got the materials from McMaster.  I struggled with the method described in the CP of slitting the tube, rolling it, and pushing it through.
I came up with a different method.  You still need to use at least 2x length of the tubing.  I put one end in the vice, and then heated that half of the tubing with a lighter while stretching it.  It thinned out and retained the rigidity when it cooled.  It slipped right through the hinge and then I pulled the stainless pin plus the unheated section through.  It worked well for me.
