Loads of surplus to requirements Vari Eze and Long Ez parts for sale
Open to sensible offers
Barely used beautiful  Gary Hertzler Silver Bullet Propeller (Serial No. P100) - 63" dia x 69" pitch for O-200 - good condition (only 192 hours use)
Used (very few hours since refurbished by Chris Lodge) Le Mere Climb Prop 57 x 56 pitch - very good as a spare or short field recovery prop
Baggage Pods with pylon foam filled and wing strap fitted for VariEze - can be altered for a Long Ez
Brand new & perfect Brock Nose Gear Retract gear assembly
Cozy III Handbook - good condition
Cozy III Section 1 and Section 1A (Full set) Plans inc. all Templates
Used but undamaged Long Ez Gear hoop with glass gear attach tabs and caliper mounting holes drilled
2 x LMGA Tubes inc 3 Top hat inserts
New Nose Gear Strut
Nose gear to Nose strut Outer & Inner Attach brackets
Standard Brock Nose Gear leg Pivot casting/plain bearing/washers
Brand new /unused Jack Wilmhelm Taper Roller Nose Gear leg Pivot asembly
New Allen  Premium Fuel Valve Part No 6S122 - direct fit Rutan recommended replacement for Vari Eze or Long Ez
Brand unused new perfect complete original Brock Vari Eze Wing Fittings in box
Brand new & unused Brock Special (LE cast on head) Vari Eze Wing Attach AN4 bolts to secure taper pins
Used O-200 6-8 amp alternator and Continental Alternator Drive Gear/Coupling - as designed by John Friling (see CP Notes CP26 Page 11
4 x O-200 Pistons, Rings and Gudgeon/Wrist pins - only 13 hours from new
Trio Ez Pilot Wing leveler/Single Axis AutoPilot (Heading/Intercept/Accepts various GPS input modes to follow flight plan) and Gold Standard Servo - perfect condition
C85/C90/O-200 Thermivalve adapter for fitting oil cooler/hoses
2 x New 30-63E Cleveland Calipers (with high power 2" dia piston)  inc Brake Plate/Linings and caliper mounting plates)
2 x Used 30-9 Cleveland/Parker Calipers (with standard 1 1/2" dia piston)  inc Brake Plate/Linings and mounting plates)
2 x Used push/pull cable operated hydraulic parking brake valves - beautiful Hoof type unit and perfect for Vari Eze & Long Eze parking
Brock Throttle/Mixture/Carb heat  quadrant control assembly - no cables
Brock Single Throttle Control quadrant for rear seat throttle control c/w cable
More parts may follow........................
Please message for more details and photos.
Thanks
Steve Brown
London
England UK
  • 4 weeks later...
Steve,
Could you e-mail me regarding Long-Ez parts for sale. Unable to contact you through forum.
MikeD
Edited by MikeD
Found other ways to contact user
Tell me and I forget.
Show me and I remember.
Involve me and I understand.
  • 2 weeks later...
New Nose Gear Strut
Thanks
Steve Brown
London
England UK
Could I get details and maybe a look?
  • 9 months later...
  • 1 month later...
