eric r Posted January 30, 2021 Share Posted January 30, 2021 I dug out my TERF CD'S and am in the process of some mods, etc. Question is; Where do I find the "A" pages referred to regarding actual dimensions of bulkheads, parts, etc? Simple measurements will do. I am putting long eze type gear attachments on a vari, and building new NG30's for electric nose install. My original NG30 is a little too short to allow clearance for the motor without modifications of F-22. In any case, I intend to beef up both NG30 and F-22 for the purpose of using the ez lift to lift loaded from the ground. As for the gear, I have the new main gear bow, the new nose strut, all available upgraded bearings, hardware, etc for the build. If I can get the main gear mount plates from CZY-GRLS, I'll gladly support their efforts. if not they are easy enough to mfg. Quote Link to comment Share on other sites More sharing options...
Kent Ashton Posted January 30, 2021 Share Posted January 30, 2021 (edited) If you want Long-ez drawings and plans they are available on this site in the “Open-EZ” topic.https://www.canardzone.com/forums/forum/394-open-ez/ Edited January 30, 2021 by Kent Ashton Quote -KentCozy IV N13AM-750 hrs, Long-EZ-85 hrs and sold Link to comment Share on other sites More sharing options...
eric r Posted January 30, 2021 Author Share Posted January 30, 2021 I must be missing something. I see the construction manual, but not the drawings depicting sizes, hole locations etc on the NG30 for example. As I said, I have the original TERF discs, but must not locating info I need. Quote Link to comment Share on other sites More sharing options...
Kent Ashton Posted January 30, 2021 Share Posted January 30, 2021 (edited) Maybe you are asking where the drawings are in the TERF CD? As I understand it, they are not. Try this post which has a file of the drawings. https://www.canardzone.com/forums/topic/35783-open-ez-rev-6-plans-and-dwgs/?do=findComment&comment=66780 You should probably start at the top of the Open-ez topic and read all the posts. There were many questions about the accuracy and how the accuracy- checking marks were labeled on the drawings but in the end the drawings are accurate. I used them to build one. The original drawings are dated however. Some of the foams have changed and there were updates over the years. I believe those are covered in the Open-ez discussion topic. Edited January 30, 2021 by Kent Ashton Quote -KentCozy IV N13AM-750 hrs, Long-EZ-85 hrs and sold Link to comment Share on other sites More sharing options...
eric r Posted January 31, 2021 Author Share Posted January 31, 2021 Yep, I figured out where to get all I need. The print bill was a bunch of $$$. Worth it though. I can make it work to my advantage. Quote Link to comment Share on other sites More sharing options...
