Paul C Posted July 1, 2019 Share Posted July 1, 2019 Hey Group. I’m sure this discussion has come up before but can’t find the thread in the archives. I recall reading not all epoxy brands are compatible with the old EZ-poxy system. What epoxy is recommended and compatible with EZ-poxy? Thanks… Paul Quote Link to comment Share on other sites More sharing options...
Kent Ashton Posted July 2, 2019 Share Posted July 2, 2019 (edited) Generally you can use any other epoxy on a cured epoxy laminate structure. The bond becomes a mechanical bond which is not quite as good as a chemical bond but mechanical bonds are all over the airplane anyway unless you built them in one day. :-) Is that your question? Take look at Gary Hunter's epoxy presentation here. It is pretty informative. http://www.cozybuilders.org/Oshkosh_Presentations/index.htm And his epoxy reference table is posted here http://www.cozybuilders.org/ref_info/ Gary is an epoxy expert for Shell, I believe, and has always been the go-to guy. Edited July 2, 2019 by Kent Ashton Quote -KentCozy IV N13AM-750 hrs, Long-EZ-85 hrs and sold Link to comment Share on other sites More sharing options...
