bhassel Posted May 27, 2009 Share Posted May 27, 2009 For those building a Long/OpenEZ how wide are you going? Thanks, Bob Quote Bob Hassel Cozy Plans #749 Santa Fe, NM http://www.cozyworld.net http://www.hassel-usa.com Link to comment Share on other sites More sharing options...
TMann Posted May 27, 2009 Share Posted May 27, 2009 Plans width internal. I rounded the exterior a bit so the midpoint of the exterior is wider. Quote T Mann - Loooong-EZ/20B Infinity R/G Chpts 18 Velocity/RG N951TM Mann's Airplane Factory We add rocket's to everything! 4, 5, 6, 7, 8. 9, 10, 14, 19, 20 Done Link to comment Share on other sites More sharing options...
SAF_Zoom Posted May 27, 2009 Share Posted May 27, 2009 Plans width internal. I rounded the exterior a bit so the midpoint of the exterior is wider. Hey TMann I don't remember if I asked before, but did you also make the back end wider to fit the 20B in there ? Quote Link to comment Share on other sites More sharing options...
TMann Posted May 27, 2009 Share Posted May 27, 2009 No. The front profile of the 20B is the same as the 12 & 13B. If you check out most installations the transition is smoother. No bumps to allow for cylinders & heads of the traditional engine. Quote T Mann - Loooong-EZ/20B Infinity R/G Chpts 18 Velocity/RG N951TM Mann's Airplane Factory We add rocket's to everything! 4, 5, 6, 7, 8. 9, 10, 14, 19, 20 Done Link to comment Share on other sites More sharing options...
SAF_Zoom Posted May 27, 2009 Share Posted May 27, 2009 No. The front profile of the 20B is the same as the 12 & 13B. If you check out most installations the transition is smoother. No bumps to allow for cylinders & heads of the traditional engine. That's right you are going normally aspirated... no turbo... Quote Link to comment Share on other sites More sharing options...
TMann Posted May 27, 2009 Share Posted May 27, 2009 That is correct. In my opinion, adding a turbo only complicates the arrangement. The attraction I have towards the Rotary is it's mechanical simplicity. I don't intend to corrupt that simplicity by adding additional complexity and points of failure. Just my choice is all. Quote T Mann - Loooong-EZ/20B Infinity R/G Chpts 18 Velocity/RG N951TM Mann's Airplane Factory We add rocket's to everything! 4, 5, 6, 7, 8. 9, 10, 14, 19, 20 Done Link to comment Share on other sites More sharing options...
mfryer Posted May 28, 2009 Share Posted May 28, 2009 For those building a Long/OpenEZ how wide are you going? Thanks, Bob Stock, plans width. Quote Link to comment Share on other sites More sharing options...
