Berkut13 Posted April 27, 2009 Share Posted April 27, 2009 I've been asked to post the following: For Sale: Complete Berkut 360 airframe* – Damage known: lower nose skin, left wing tip, and lower aft bay. Major structural damage to nose and main landing gear and associated internal bulkheads. Miscellaneous damage to hydraulics, wiring, and fuel lines. Includes: IO-360-EXP (<20hrs TTSFR, constant speed version by Performance Aero Engines) - 10:1 compression - B&C starter - Dual Lightspeed Plasma III ignitions - B&C 90-degree oil adapter - 40amp B&C alternator - 20amp B&C stand-by alternator (vac pad) - B&C primary and secondary alternator regulators - MT propeller governor on accessory case - 9-row Positech oil cooler - Bendix RSA-5 fuel injection system - Lycoming mechanical fuel pump - Weldon high-pressure electric boost pump - Over/Under 4x4 exhaust pipes MT 3-blade “Performance” Constant Speed propeller IK2000 Engine monitor and Flight data units w/probes and DPU Dynon D-10A ACK Altitude Encoder Garmin Audio Panel Garmin 430 GPS/NAV/COM Garmin SL-40 COM Garmin 427 Transponder Garmin OBS/ILS indicator head – physically damaged S-TEC SL-30 autopilot with GPSS & pitch and roll servos Flightcom voice/audio recorder Whelen NAV/Strobes – left wing unit damaged Ameri-King ELT & whip antenna PC-680 main battery $50,000 o.b.o takes it all. Not parting-out at this time. If you have specific questions, please contact Scott directly: lscharlton@sbcglobal.net Serious inquiries only, please. *Airframe to be sold complete as “Salvage” only – as is. Quote Link to comment Share on other sites More sharing options...
TMann Posted April 27, 2009 Share Posted April 27, 2009 How did all this damage occur? Quote T Mann - Loooong-EZ/20B Infinity R/G Chpts 18 Velocity/RG N951TM Mann's Airplane Factory We add rocket's to everything! 4, 5, 6, 7, 8. 9, 10, 14, 19, 20 Done Link to comment Share on other sites More sharing options...
pavan Posted April 28, 2009 Share Posted April 28, 2009 Hope occupants are fine. Request pictures. Thanks, Himalaya. Quote Link to comment Share on other sites More sharing options...
