spitzy Posted October 27, 2008 Share Posted October 27, 2008 Are you supposed to file notches into the torque tubes on both sides of the NC-2 Insert? Quote Link to comment Share on other sites More sharing options...
mfryer Posted October 27, 2008 Share Posted October 27, 2008 I sure hope so. That is what I did! (Long-EZ plans) Quote Link to comment Share on other sites More sharing options...
spitzy Posted October 27, 2008 Author Share Posted October 27, 2008 It's the "A notch" description in the plans instead of maybe something like "one of two notches" that makes me wonder... There was a picture in the plans also but it isn't clear enough to tell one way or the other. I can't think of a reason why you wouldn't make two notches other than maybe there would be a small reductionin strength. It looks like it only making one notch could limit travel of the elevator but I'm not sure. Quote Link to comment Share on other sites More sharing options...
mfryer Posted October 28, 2008 Share Posted October 28, 2008 Well, because it did not specify fore or aft side of the tube, I presumed it meant both. Quote Link to comment Share on other sites More sharing options...
Cozy Girrrl Posted October 28, 2008 Share Posted October 28, 2008 You need it on both sides to get adequate throw, it will become obvious if you put an NC-3 in place and slide the hinge pin in there. ...Chrissi Quote CG Products www.CozyGirrrl.com Cozy Mk-IV RG 13B Turbo Link to comment Share on other sites More sharing options...
