tomlaudato Posted May 8, 2008 Share Posted May 8, 2008 I have been following builders for longez type airplanes. Seems as though the finished weight of these are all over the map. My question is the weight of the complete airframe (stock) Can someone with experience help me answer? excluding anything bolted to the firewall aft and excluding anything on the panel (just blank) what would the weight of a complete long ez ready to fly except the above weight guess (............) with amateur builder no carbon no vacuum bag weight guess (............) middle of the road builder no carbon/vacuum bag weight guess (............)weight guess experienced builder no carbon/vacuum I am trying to figure out where all the weight differences is going with all these different builders before the engine and the avionics......... thanks in advance for any help putting this to rest for me tom tomlaudato is offline Reply With Quote Quote Link to comment Share on other sites More sharing options...
Waiter Posted May 9, 2008 Share Posted May 9, 2008 My guess is the extra weight is FRU-FRU. My WAG is a LongEZ built by a carefull builder with NO fru-fru, An O-235, with minimum instruments and electrical, and minimum filler and paint, Probably 750 lbs. I don't think you would see a 25 - 50 lb savings between an average builder and someone who Vac Bagged. So, Where the extra 200 lbs come from? Filler and finish, electrical system, radios, instruments, oxygen tanks, larger engines, larger batteries, etc. Waiter Quote F16 performance on a Piper Cub budget LongEZ, 160hp, MT CS Prop, Downdraft cooling, Full retract visit: www.iflyez.com Link to comment Share on other sites More sharing options...
RGlos Posted May 9, 2008 Share Posted May 9, 2008 See Attached Canard Weights II.xls Quote Link to comment Share on other sites More sharing options...
Drew Swenson Posted May 9, 2008 Share Posted May 9, 2008 Don't forget us light weight pilots with big engines and short noses---need lots of ballast. Quote Link to comment Share on other sites More sharing options...
