King Racer Posted November 22, 2007 Posted November 22, 2007 My E-Racer construction manual (Chapter 12) calls for 5 mm red PVC foam for top and bottom surface of the strakes and 0.25" Klegecell or PVC foam for the baffles. Would 0.25" divinycell (3 lbs/cuft ? or 6 lbs/cuft ? or 15.6 lbs/cuft ? - density is not specified in plans) be the correct material/density to use for the E-Racer strakes? Thanks Quote
Richard Schubert Posted November 22, 2007 Posted November 22, 2007 I believe the stuff you want is the H45 3lb http://www.airchttp://www.aircraftspruce.com/catalog/cmpages/divinycellfoam.php It comes in the right sizes. The 3lb density is more flexible than the heavier stuff and will conform to the curves better when you bend it. Quote "We choose to do these things not because they are easy, but because they are hard." JFK
Richard Schubert Posted November 26, 2007 Posted November 26, 2007 Sorry, Here is the correct link http://www.aircraftspruce.com/catalog/cmpages/divinycellfoam.php also My copy of cozy mk3 plans shows H45 PVC .35 in. thick for these parts. My e-copy of cozy Mk4 plans shows H45 PVC 3/8" thick I believe the 5mm (.196 in.) PVC has been discontinued except in the 18# weight, Quote "We choose to do these things not because they are easy, but because they are hard." JFK
rickh Posted November 27, 2007 Posted November 27, 2007 I've the Divinicel "H" grade tech manual, no mention of colors, nada. Like Mr. Schubert said, the Cozy uses 3/8" H-45 for the strake skins and inner bulkheads. Try www.fiberglasssupply.com ? They cater to the hydraulic crowd (surf boards), but their website lists several thicknesses and grades of Divinicel. No connection, but I have ordered other stuff from them in the past. Rick Quote Rick Hall; MK-IV plans #1477; cozy.zggtr.org Build status: 1-7, bits of 8-9, 10, 14 done! Working on engine/prop/avionics.
