hi guys i reded somewhere about cut the canard about4" short from original measurement my guestion is if its from overall dimensions or 4" from each side and why is that thank you
Where did you read that? You don't want to cut your airfoils unless you're absolutely sure you know what you're doing AND you have also discussed with others with VariEze-specific knowledge and experience.
Read through the Canard Pusher newsletters. If there's no mention in there, then I'd be very hesitant to do anything.
You read that in :
VariEze
Manufacturing Manual
Section IIC - Lycoming O-235 Engine.
Second edition.
Page 37 of 39. Modification of the canard.
You ask : "cut the canard about4" short from original measurement my guestion is if its from overall dimensions or 4" from each side "
Answer is ==>> 4" off each tip.
Original canard is 150", and is shortened down to 142".
The purpose is to ""move aft 1.2" allowable CG range. It is equivalent to adding 15-lb weight to the nose at FS-5"". Section IIC dixit.
"The canard trim to 142" span lowers the allowable pilot weight about 30lb. If the air plane were originaly designed for the O-200 with alternator, the canard would have been 142" span. etc........"
"If you know you are going to use an O-200 or a Lycoming O-235 and your weight is less than 180lb, go ehaed and trim it now, before your paint job. Same goes with A75 engins if your weight is less than 150lb."
Do get this page for more details.
As far as I know, in France all canard are 142", to get more aft CG range.
I fly a varieze O-235 powered with this 142" canard.:)
I first fly it with at 150", but was close to disaster..........:(
Do get this page in US and read it for better explainations.
Regards.
Gilbert.
VE 1736
F-PMPZ @ LFPK (France)
Same explaination in this message from Spodman <<Choosing a length for the canard>> :
Lengthy cut'n'paste from an old CP (from when there were about 20 Varieze flying) which leads me to understand something I didn't before - a heavier motor and a longer canard are both ways toward an aft c of g:
"Those of you who do have the heavier engines and alternators are
finding that the nose weight needed to get the cg forward is cutting
into your useful load, already reduced with the heavy engine. If this
were a conventional airplane there wouldn't be much you could do, short
of moving the engine or wing. But, since the VariEze has two widely
separated, lifting wings, the allowable cg range can be shifted by
shortening or lengthening the canard. Thus a "tailheavy" airplane can
be made to fly "nose-heavy" merely by sawing off canard span, making no
change to actual cg! This can be done only up to a point, where
directional stability is lost as cg is moved aft. We have tested the
flying qualities and confirmed that the canard/elevator is free from
flutter at two canard spans - 150" as shown in the plans and 142" which
is obtained by sawing 4" off each tip. If 4" is sawed off each canard
tip (142" span) you can move the allowable cg range aft 1.2 inches.
This is equal to adding 15-lb weight in the nose at F.S. 5.
Let's look at a couple of examples to see what this canard trim can do
for you. Assume you weigh 170 lb and you are using an 0-200 with
alternator and a small battery. When you do your weight and balance
you find you will need 30-lb ballast in the nose to get to the nose
heavy condition (preferred for low pitch sensitivity) for first flight.
Then later you can remove 1/2 the ballast, but will have to carry 15 lb
of lead in the nose for the life of the airplane. If you trim the
canard you will find that you only need 15-lb ballast to get to the
forward cg you need for first flight. Then, when you are comfortable
with the stick forces you can remove all ballast and have the best
useful load and a mid to aft cg. Thus, trimming the canard has
increased your useful load by 15 lb!"
Gilbert.
VE 1736
thank you that is sounds logical i talked to one guy who did that but i never asked why now i know yes im going to use continental engine and im 165 lbs so i think it will work for me well
