zzigster Posted October 5, 2005 Share Posted October 5, 2005 Does anyone know if there is an approved procedure for the replacement of aileron hinges on a Vari-eze? Any help would be greatly appreciated. I have one hinge that is beginning to get a little sloppy and need to begin planning a fix. Quote Rodney Herzig Link to comment Share on other sites More sharing options...
argoldman Posted October 5, 2005 Share Posted October 5, 2005 Does anyone know if there is an approved procedure for the replacement of aileron hinges on a Vari-eze? Any help would be greatly appreciated. I have one hinge that is beginning to get a little sloppy and need to begin planning a fix. you may be a perfect canadate for a teflon hinge insert and rod, Rod. I don't know the website off hand, but look for links on this and canard community for "teflon" My understanding is that you remove the pin, insert the teflon and insert a new supplied pin. That might solve your problem in an easy elegant fassion Saving a lot of work hinges on hour finding that link Quote I Canardly contain myself! Rich Link to comment Share on other sites More sharing options...
Remi Khu Posted October 5, 2005 Share Posted October 5, 2005 Does anyone know if there is an approved procedure for the replacement of aileron hinges on a Vari-eze? Any help would be greatly appreciated. I have one hinge that is beginning to get a little sloppy and need to begin planning a fix. Hi Rodney, You have two options: 1. Visit Gary Hall's site to purchase the aileron hinge retrofit kit, or 2. If you are a CSA member, contact Terry Schubert for his retrofit kit free Here is Gary Hall's URL http://www.uslan.com/hinge-kit.html Terry Schubert can be reached at: jschuber@juno.com HTH, Quote Remi Khu Cozy Mk IV Plan #1336 Link to comment Share on other sites More sharing options...
