John Slade Posted April 12, 2003 Share Posted April 12, 2003 I'm fabricating an intake system for my 13B turbo. I'll be using the cast manifold and runners from Lamar and building my own plenum using my fancy new TIG welder. The recommended throttle body is from a Mustang 5.0, but I'm not sure what size to get. I've had suggestions ranging from 65mm to 75mm. Any thoughts? Quote I can be reached on the "other" forum http://canardaviationforum.dmt.net Link to comment Share on other sites More sharing options...
Dave Clifford Posted April 13, 2003 Share Posted April 13, 2003 Wish I had known that last month John. Last summer I came across a retired Ford engineer who designed fuel delivery systems. He always aquired one or two he had helped on when they went into production. He retired a couple years ago and was moving. He sold them to me at his garage sale dirt cheap. I auctioned the last three off last month on Ebay for $49.00 @. I had two for the 5.0 Mustang, a 65mm and the 75mm H.O. Brand new. Bolt on, plug in and go. Quote Dave Clifford "The Metal Man" Musketeer Vise grip hands and Micrometer eyes!! Cozy MKIV Plans #656 Link to comment Share on other sites More sharing options...
Aaron Posted April 13, 2003 Share Posted April 13, 2003 Usually you want to keep your inlet velocity lower than 300 ft/sec (reference: Corky Bell) non-turbo (assuming flow of 450 cfm ) 450 cfm/(300 ft/s * 60 s/min)=.025 sq ft area required turbo (assuming 600 cfm) 600 cfm/(300 ft/s * 60 s/min)=.033 sq ft required 65mm=.0357 sq feet area 75mm=.0475 sq feet area It looks like the 65mm is big enough even under the turbo load. If you go too big, part throttle suffers greatly, and it would be embarrasing to stall out on the taxiway Quote Link to comment Share on other sites More sharing options...
John Slade Posted April 13, 2003 Author Share Posted April 13, 2003 Scary. There's a theory for almost everything. Thanks Aaron. Quote I can be reached on the "other" forum http://canardaviationforum.dmt.net Link to comment Share on other sites More sharing options...
