dust Posted April 11, 2003 Share Posted April 11, 2003 so we put both of the fuselodges together and the front seat was out of square by 1/8 inch and we were really worried and we called nat. His comment, if you are not at a 90 degree angle to the front to the front, it is ok! The point of this post, build the plane, even is you make minor screwups it will be OK. In my humble opinion the plane is overenginerred to the point that a poorly built plane will still be safe. Who among you will build poorly??? Please speak up. Quote maker wood dust and shavings - foam and fiberglass dust and one day a cozy will pop out, enjoying the build i can be reached at http://www.canardcommunity.com/ Link to comment Share on other sites More sharing options...
marbleturtle Posted April 11, 2003 Share Posted April 11, 2003 I'm thinking about using two 9000RPM motocycle engines to power two duct fans instead of a big single prop... does that count? Quote This ain't rocket surgery! Link to comment Share on other sites More sharing options...
