Aaron Posted March 29, 2003 Share Posted March 29, 2003 I know there's a specific work table in Chapter 3, has anyone gone the route of EAA chapter 1000's standardized tables? the idea is you build 2 to 4 tables, all 2 feet by 5 feet. When you need a large table you level them all and bolt them together, when you don't need a large table, you've got one just the right size. http://www.eaa1000.av.org/technicl/worktabl/worktabl.htm Any opinions appreciated. Quote Link to comment Share on other sites More sharing options...
Jerry Schneider Posted March 29, 2003 Share Posted March 29, 2003 That sounds like a pretty good idea for some. But, I prefer one big table, made exactly straight plum, and level. I use it quite frequently as a reference for jigs, wing building and such. Also, my shop floor is quite irregular, so, moving and joining tables would require a bunch of adjusting each time I decided to use an additional table. That being said.... If I were working out of a smaller area, (ie: garage), I think it would be a good idea. Nothing like being wish-washy, huh? Quote "I run with scissors." Cozy MKIV N85TT Phase One Testing http://home.earthlink.net/~jerskip Link to comment Share on other sites More sharing options...
dust Posted March 30, 2003 Share Posted March 30, 2003 If space is a concern, then do it, if it is not, I wouldn't do it, building 4 tables takes at least twice a long and for moxt of the building, the entire table is used. I can't think of many times we didn't use all of it. Even when you are doing internal fuseloge reinforcements, we found that laying out the reinforcements on plastic coverred butcher paper and literally covering the bench with various sizes and shapes as called out for in the plans took the whole bench and then some. As you work you can't really clean the bench, it is better to move to a clean section and then the next day scrap and wax the bench. In other words build it you will use it, all of it, allmost all of the time Quote maker wood dust and shavings - foam and fiberglass dust and one day a cozy will pop out, enjoying the build i can be reached at http://www.canardcommunity.com/ Link to comment Share on other sites More sharing options...
