flyjunky Posted August 12, 2002 Share Posted August 12, 2002 I'm seriously considering building a Cozy IV, starting in the basement, then moving to the garage as required. Anyone have techniques to keep the dust out of the rest of the house? Thanks. Quote Dreaming and Thinking Link to comment Share on other sites More sharing options...
John Slade Posted August 12, 2002 Share Posted August 12, 2002 Sealing the door to the basement and putting in an exhaust fan should work. Bulent Alieve built his fuselage in the living area of his apartment... but then he was single at the time Seriously, you can build a LOT without hardly any dust. Bulkheads, fuselage sides, aluminum hardware etc. Its only when you start sanding the fiberglass and micro that dust becomes a big issue. Also, you might consider using MGS epoxy so you dont stink ont the whole house with epoxy smell. The sooner you start the sooner you'll be done. Quote I can be reached on the "other" forum http://canardaviationforum.dmt.net Link to comment Share on other sites More sharing options...
dust Posted August 13, 2002 Share Posted August 13, 2002 I have two hobbies and dust is what I make. If you were asking about furniture building, I would say - DONT DO IT IN THE BASEMENT!!!! But Glass work ins't that bad, thats not to say you don't create dust, just not in the quantities that you do in woodworking, untill you start filling and sanding. Filling and sanding is left until the end and you can find other quarters for that operation. Most of the dust in the building process is heavy enough to settly locally for vacuuming and sweeping, it's not the insidiouse kind that floats to every nook and cranney from floor to ceiling, like wood sanding dust, in the construction phase. Mike chap 19 see my post on getting started Quote maker wood dust and shavings - foam and fiberglass dust and one day a cozy will pop out, enjoying the build i can be reached at http://www.canardcommunity.com/ Link to comment Share on other sites More sharing options...
