Kimjensen Posted October 18, 2017 Share Posted October 18, 2017 Hi All Looking for some parts for the airbrake and the handle for the nose lift. If you got eny other parts for a cozy mk3 please write ) Quote Link to comment Share on other sites More sharing options...
Kent Ashton Posted October 20, 2017 Share Posted October 20, 2017 Kim, You might want to make a handle if you have the tools because (1) you will have to weld or rivet a shaft later on it later and (2) the plans handle needs a mod to keep it from rotating which requires some welding. Below is a handle with a long nut drilled out and welded on it. The nut passes through a suitable ratchet wrench that is adapted to the instrument panel. For the landing brake, I have installed both the manual brake and the electric brake and the electric one is only a few ounces heavier and easier to install, IMO. There are very few parts to make for the electric brake and there is a fair amount of fiddling to install the cable-operated mechanism on the manual brake. If you need the actuator number, I will look it up for you. 1 Quote -KentCozy IV N13AM-750 hrs, Long-EZ-85 hrs and sold Link to comment Share on other sites More sharing options...
