wolf. Posted December 15, 2008 Share Posted December 15, 2008 Dear Sirs, lately I am having more and more difficulties extending my speed brake (a plain vanilla O-290 Long Ez, which I did not build) even at 60-70kts I need both hands where before at 90 one hand was enough, on the ground it feels light. Am I just getting week or did something shift in the mechanic which I am to blind to see?? Any advice wellcome wolf. Quote Cosy Classic flying (ex LX-ACE) Varieze N39JC rebuilding Link to comment Share on other sites More sharing options...
saybeengineering Posted December 16, 2008 Share Posted December 16, 2008 Is there substancial friction when deployed on the Ground???? Is the cable assembly free from obstructions???? How is the tension of the cable?? You can also lift the nose to a higher angle of attack to reduce the speed, deploy and then lower the nose. Finally, you can convert the mechanical assembly to an electric one and forget about the struggle in final approach.....Wayne Lanza from Composite Designs makes a conversion kit. Contact him at wlanza@bellsouth.net. Regards, Afif Saybe Long EZ HR-ATQ Honduras Quote Afif Saybe Long-EZ, HR-ATQ Link to comment Share on other sites More sharing options...
Drew Swenson Posted December 16, 2008 Share Posted December 16, 2008 Sounds pretty weird. Are you sure that your airspeed indicator is correct? Check to see what speed the board auto retracts---needs to close at 95 kts. Landing brake springs need to be adjusted so that you have a 40lb pull on the trailing edge of the brake to close it. If it pulls closed with less than 40 lbs, you need to tighten in up. If more than 40 lbs, you need to loosen it. Seems strange that it is easy to operate on the ground---sort of eliminates any binding problems---unless you have stuff that can shift in there while airborne (is the opening in the side of your armrest such to get your coat or seat cusion caught in the device? Quote Link to comment Share on other sites More sharing options...
wolf. Posted December 18, 2008 Author Share Posted December 18, 2008 Thats a good point I will check if something is caught in the mechanism. wolf. Sounds pretty weird. Are you sure that your airspeed indicator is correct? Check to see what speed the board auto retracts---needs to close at 95 kts. Landing brake springs need to be adjusted so that you have a 40lb pull on the trailing edge of the brake to close it. If it pulls closed with less than 40 lbs, you need to tighten in up. If more than 40 lbs, you need to loosen it. Seems strange that it is easy to operate on the ground---sort of eliminates any binding problems---unless you have stuff that can shift in there while airborne (is the opening in the side of your armrest such to get your coat or seat cusion caught in the device? Quote Cosy Classic flying (ex LX-ACE) Varieze N39JC rebuilding Link to comment Share on other sites More sharing options...
TMann Posted December 18, 2008 Share Posted December 18, 2008 Thats a good point I will check if something is caught in the mechanism. wolf. I would also suggest having someone provide resistance to the panel to duplicate the forces you are encountering in flight. The fact that it seems to operate fine on the ground with no resistance would lead me to believe that something in bent just enough to cause problems when in flight. When doing this have them apply pressure to the trailing edge of the panel and check to make sure the hinged area appears to be okay and that the panel does not distort when varying the pressure from one outside corner to the other. Just a thought. Quote T Mann - Loooong-EZ/20B Infinity R/G Chpts 18 Velocity/RG N951TM Mann's Airplane Factory We add rocket's to everything! 4, 5, 6, 7, 8. 9, 10, 14, 19, 20 Done Link to comment Share on other sites More sharing options...
wolf. Posted March 31, 2009 Author Share Posted March 31, 2009 Hi guys I resolved my speed brake trouble, it was the pilot I had 3 times surgery to get rid of a gut cancer and was just to weak for my speed brake, now after some time I regained my strenght and the speed brake can be deployed without much trouble:cool2: Quote Cosy Classic flying (ex LX-ACE) Varieze N39JC rebuilding Link to comment Share on other sites More sharing options...
Phil Kriley Posted March 31, 2009 Share Posted March 31, 2009 Hi guys I resolved my speed brake trouble, it was the pilot I had 3 times surgery to get rid of a gut cancer and was just to weak for my speed brake, now after some time I regained my strenght and the speed brake can be deployed without much trouble:cool2: That's good news - especially that you are regaining your strength after your surguries! I hope your health continues to improve! Quote Phil Kriley Cozy #1460 Chapter 13 - nose Right wing done - working on right winglet. Link to comment Share on other sites More sharing options...
