Washout - Twist in VariEze wing
Joe Hinkle
The LEZ and Cozy identify the amout of Washout (twist) in the wing on the wing drawing ....
On the Cozy - Chapter 19 - page 10 ....
Drawing shows .6 degrees washin at the strake interface and 2.7 degress washout at the wing's tip.
If you have a drawing of the VariExe's wing - could you please share what Burt identified as those values.
Thanks.
I have that document and have studied it.
It does not state the amount of washout.
The wing section has the following statement:
Tip Incidence, deg = -1.8
I take that as a measurement of the actual aircraft - not the design criteria.
If that is correct, then the VariEze had a washout of 1.8 degrees and the LEZ/Cozy has a washout of 3.3 degrees over it's wing span.
Does anyone know what the design criteria was?
  • 2 years later...
