Anthony P
56 -
3
Posts posted by Anthony P
https://q-list.groups.io/g/main
https://imageevent.com/qdf_files/quickiefiles
Also, search Q-Tour on youtube. The experts are there.
The one in IN on barnstormers looks good. I would be all over it if I wasn't set on the original canard and gear. 635# empty is fine.
- 2
Great videos.
Thanks for sharing.
You should join and post this to the Dragonfly list. That list needs some inspiration.
What are your thoughts about carefully grinding and smoothing a 0.5" dia. or larger "stop crack" before the flox and reinforcement layups?
Not suggesting this, just wondering if this pre-layup geometry would make the repair worse, only a little better, or no change.
Thanks,
Congratulations!
That is amazing and the bird looks great!
DOH!
Palm to forehead. 😒
I search for "Q2", "Q200", and "quickie" and can't find this ad.
Search for "Q-2" and there it is.
Super annoying.
Jon, I sent a PM to you regarding your Q2 kit.
- 1
Sounds like you have a lot of good stuff.
To be clear, I was saying that the Barnstormers listing could be free, not the Q200 project. (I read my earlier post again and it seemed ambiguous at best)
I'm sure someone will need it and you will get some money for it.
As Kent said, put it on Barnstormers for free.
Nothing wrong with the original wing, and many never permanently attach the tail (rear portion of the fuselage). This makes it compact for storage and easily transported on trailer when turned sideways.
Do you have engine, canopy, or any hardware?
I had the pleasure of meeting Dave and his Q2 earlier this week.
Both are great!
- 1
Awesome!
Can't wait.
Another one:
Coming up next month:
August 8, 2020 at 09:00 USA Central time. Dave Dugas and his award winning Revmaster powered Q-2.- 1
I thought the idea was to mold the wing skin (and other parts) in one or two pieces and then pour/spray the "right" foam in there to create the current structure but with a perfect exterior finish and shape. The molds are of course the problem, and the "right" foam can't balloon the skins while it's curing.
Darkaero is molding wing skins and then bonding ribs inside.
Another French company is making "cheap" carbon fiber planes with single piece molded wings that (I think) don't have any internal structure.
Thanks Kent.
The process you describe here seems to break down if the current owner is not the manufacturer.
18 minutes ago, Kent Ashton said:Or do a Make/Model search for Model "Dragonfly" which will return 323 Dragonfly entries with Manufacturer names, see pic below. If the "Manufacturer" in the 3rd colum is an individual [builder/owner] like Bailey Robert E do an individual Name Inquiry for his name (use the same name format). That will return the N-number for that owner which you can search for all the info. If the 2nd column has highlighted info like NORTH CAROLINA - 1, click on that and it will show you N-number info. If the Manufacturer is a commercial name like AVRO none of this works. Yeah, easy right 😞
Name search only returns current owners and N-numbers for me.
Model search only returns manufacturers with no other useful info.
When I do a Model search on FAA Registry, all it gives me is the manufacturer and nothing else that seems useful.
Does anyone know the secret easy way to cross reference this with N-number, and/or current owner, and/or current address?
I'm looking for Q2 or Dragonfly in New England.
Thank you,
Ok, Got it.
Thanks everyone.
Regarding my second question in the original post, I asked that because I'm also interested in installing a 4 cyl. D-motor in a Dragonfly. That question has been answered here.
If I labeled my helicopter as a lighter-than-air ship, do you think ATC would be scratching their heads when I made my inbound call?
You have already answered my question, so I think I'm just taking up valuable space on the interweb. But here we go...
Why do I care:
1. If my government is going to keep records, I at least want them to be correct. Otherwise, stop bothering and give the taxes back to me/us.
2. I'm investigating this aircraft as a potential purchase and want to know why the record is incorrect and how to fix it. Wouldn't you want the records to be complete and correct before purchasing an aircraft?
You say the registration is acceptable to the FAA. I guess it is, but why?
The proof of incorrect/incomplete registration is in this ad. https://www.trade-a-plane.com/search?category_level1=Piston+Helicopters&make=ROTORWAY&model=EXEC+162F&listing_id=2375298&s-type=aircraft
The registration should look like that of N99TE. (except, not deregistered)
Thanks again, Anthony
No, it's not my plane. And, you are making my point. It's not even a plane, it's a helicopter. 😤
Because it's a kit, we know the engine manufacturer and the engine model. The model of the aircraft is named after the engine for goodness sake.
We also know the manufacture year. I'm at a loss as to how this could be "in order".
If this is how the FAA rolls, then I guess I can write anything I want on the registration.
N162NL is an example. Not a gyroplane. Don't know how this got soo screwed up.
But, my question was generic regarding correcting FAA experimental aircraft registrations.
Your info on engine changes makes sense. I was wondering if there was a significant difference between a plans built aircraft and a kit built aircraft in terms of engine changes or other large deviations from the plans/kit.
Thanks a lot Kent for gathering and sharing all of the information you do. I have learned a lot in the last 9 months.
Hello all,
I've been reading the related threads on here about the above questions and would like some more help if available.
Short of contacting the FSDO, DAR, and local EAA, what are your opinions or suggestions on the following questions?
1. Current experimental aircraft registration: Type incorrect, Manufacture date missing, Engine manufacturer incorrect, Engine model missing.
How much of a pain is this going to be to correct? Is this something I should get corrected before buying? If I attempt this correction after purchase, what form/evidence will I need?
2. If not referenced in the Operating Limitations for the aircraft, what am I going to have to do to change the engine (manufacturer and model) on a kit built experimental aircraft that I did not build?
Thank you and happy 4th, Anthony
Where in the world do you guys see threads???
I see a shaft that was spun in a bench vice! 😀
Ok John W, I thought you may be converting to the straight wings of the Mk2 or even gull wings to increase wing tip ground clearance.
Sorry I can't help on the layup schedule for the hoop landing gear.
Join and ask here: https://dragonflylist.groups.io/g/main
John W, are you going to have a spare Mk1 front wing lying around?
If so, I may be interested.
Kent's Long-EZ project
I can hear the blood boiling now! 🥵
Sorry.
