CA Mailing List
12,282 -
Posts posted by CA Mailing List
I wrote:And a few of them have decided that they're not interested in coming out of the spark plug holes, but would rather commit suicide:So here's what I actually did to remove the stuck adapter:
- I blew air through the cylinder with the piston at TDC by attaching a compression tester adapter to the bottom plug hole
- I used a suggestion to grind away 90% of the adapter, pretty close to the helicoil (the air blew ~90% of the crap out of the cylinder, but not all. Since the adapter was the ancient steel one that LSE used to sell, I was able to use a small magnet to fish out 99% of what fell into the cylinder)
- I then used an 18mm x 1.5mm tap to re-tap the hole and was able to get the tap started in the top of the helicoil to ensure it was lined up correctly. I made it through 95% of the hole, getting clean threads and exposing the helicoil using oil on the tap and collecting chips every three threads or so (and fishing more out of the cylinder with the magnet)
- But sadly, the helicoil spun when tapping the last 2 threads in the hole (isn't that always how it goes?) so I removed the helicoil and re-tapped the helicoil insert threads with the helicoil tap
Thanks to all for the suggestions - a combination of them worked fairly well and only took a few hours.-- -
Tracy Ryan wrote:
Should be either 164-01700(standard) or 164-11700(chrome)...
Yes - I found the 01700 as the stock disc for that wheel/brake, but those are the 3/16" (0.187") thick discs. I'm looking for a 1/4" thick disc.And per the catalog, the 30-9 caliper has no shim. Only the 30-181A caliper has the shim. Not sure why someone would put that in when it’s not needed.
The shim was installed because the disc thickness was increased from 0.187" to o.250". Hence both the shim and my question about which disc #, out of the four 0.25" thick discs I listed, I should be purchasing._IF_ their numbering system is consistent, then PROBABLY the 01300, or 01900, but that's why I'm asking :-).-- -
I have the thicker ones on my RV6A. I did not know of multiple part number possibilities.
I will check my part numbers tomorrow...
Sent using myEarthLink
Folks:So there are apparently 4 different Cleveland/Rapco P/Ns for 0.25" thick brake discs for 5.00 x 5 wheels (as used on a Long-EZ) to the extent I can tell. These are:164-00900164-01300164-01900164-02800Assuming I have a fairly standard Cleveland 40-78B wheel with a <mumbledy> single piston brake caliper that has a 1/8" thick spacer in it (apparently the brake was upgraded to a thicker disc at some point), which of these discs should I get, and how would I know that?Thanks in advance.--
After I put the nose down my wife sits on the strake and just slides off. Sometimes she says "Weee".
Charlie, how did that de-plane procedure work after the $100 burgers? Or is it $250 now…Steve WolpinFrom iPhone
To the delight of line people all over the country, Madeleine and I devised the most efficient, although perhaps the least elegant method to deplane her. She would stand up, I would position myself in front of the left strake, and she would “fall” over my shoulder like a sack of potatoes. I would then turn and gently lower her to the ground. It was the best and safest way, and always good for a laugh!Cm
VLC media player on a Win 10 PC seems to play that file just fine.
It is open source and has multi platform versions.
Harry A. -
Bill-Yes, sorry, for Windows machines only.But for non-apple people I highly recommend-very customizable.Still don't know what a .mod file is, but I was able to watch it.-Christian-- www.BrilliantDesignOnline.com
Solidworks Design & CNC Plasma Cutting
-a division of-
www.AlpineWorldwide.com
"We build ideas.." -
Same here - and as I cant find “Pot Player” for IPad, I’ll never be able to open it….Bill
Use 'PotPlayer', a Korean very good version of a Windows Media Player like application; plays everything.-Christian-- www.BrilliantDesignOnline.com
-a division of-
Steve, All,
I believe that the material that John and Sue refer originated from me ;^)
I did get to my field this weekend.
I took stills of my latch in 'open' and 'closed' positions, attached.
As Bill requested I have dipped into the world of cinema and made an epic of its operation, due to size. attached to a separate email.
Most of the canard community these days are not the original builders - the old-guys would have had no trouble reproducing my latch from my rather poor annotated photos.
I didn't manage to lay-on a scale but the longeron thickness should act instead.
Best with it!
Mike T O-235 VE G-EMMY
Thanks Sue/John. I'll consolidate yours and Mike's and see if I have what I need to grok the ops of this creature.
Cheers. —Steve
On 4/3/2024 12:22 PM, Sue Fritz via groups.io wrote:
Apologies gals and guys,
Just discovered!
This new email tucks away all the replies so I couldn't see what I or Bill had sent!
B***dy annoying!
Apologies,
Mike T
Hi Bill, All,
That returned ok.
So I'll send my original email attachments - perhaps the attachment were too large in total??
I'll re-send just two of my picis.
The original text is as below. (sorry about the size of my print next size down is too small!!
Mike T
Hi Bill,
Thanks.
But I haven't received my own email that I sent as a reply-all to Sue's request.
Am I still [c-a]??
Mike T
Hi Mike,If you do get down there (if it ever stops raining) a couple short videos of it working from different POVs would be great too.You can easily put them up on Vimeo or YouTube so folk can interpret the drawings more readily.Good work!Bill
Sue, John, Steve,
I now have a new PC, thus I am struggling with Windows 11!! (Can't find a darned thing!)
Further I had to go for M/S Office 13 as no way was I to pay per month! for 365 Word/Excel/etc.
I have now looked-up those pictures I took some years back.
At the time I did not produce engineering drawings (very unlike me).
Note I had before overlayed the original 'Burt handle', for extra leaver-arm for my daughter. - This became part of the arrangement
Attach 1 shows the basic layout with the 'canopy closed, latch made'. (canopy obviously open to allow more light for the photo.)
Attach 2 The main components (handle, latch, barrel lock) positioning from top longeron. (microswitch arm just visible)
Attach 3 Annotated to give an idea as to the action of handle/latch and, separately, the barrel lock.
Attach 4 Gives an idea as to the operation.
Remember to move the 'safety catch' to as far back as the pilot's seat etc. will allow for GIB access
However, I aim be at my field this weekend. It's an hour away so no-go if we get bad Wx.
I will attempt to take some better/more informative shots and try to include a measuring tape to give an idea of size etc.
It shouldn't be too difficult to mock-up a card 'prototype' based on the above which will allow you to see its operation and then transfer it to hardware, ally sheet, etc.
Note: I have spacers under my latch pins/screws so that they are in tension not bending OMV
Steve,
Attached is the email, from Feb 9, 2015, that I believe Mike was referring to regarding his GIB emergency canopy release.
John
On 4/3/2024 11:34 AM, stephen wolpin wrote:
For Mike Tooze and anyone else who fabbed a smart solution to the challenge of getting the canopy opened from the back seat, unassisted.
Did you ever dig up your pics/detail of your Gib Canopy Escape linkage? Would like to see how you did that and any thoughts on refining it, after all these years.
—Steve Wolpin
Thanks everyone! I think we got the situation figured out.
David Kissick
Cozy Mark IV
http://www.cozyserenity.net
Re: COZY: Re: [c-a] 5.00 x 5 wheel Brake Disc P/N
in Canard Aviators Mailing List (read-only)
View the full article
