wolf.
77 -
Posts posted by wolf.
Any news on the rotax for the VE? I am also interested
wolf.
Dear all, is it possible to install the hidden rudder beellhorns in the VE?
Who has done so allready and would it be possible for me to have the instructions (the parts I would by from the girrrls)
wolf.
I have had the same problem with a completely different set up. I had an old sender and a westach instrument, now I have a new sender and an EFIS. But I'lll still try changing the sender.
wolf.
I have a Long with a O-290,
since a while every now and then the Oil P drops to zero or below 10psi then comes up again and so forth, if the engine is running for 20 min or more it happens less frequently. I have the non adjustable cage type relief valve. I cleaned the valve replaced the sphere and the spring and it worked for 3h flight now it does it again. Any ideas what the problem could be?? (zero Oil P makes me somehow nervous in flight)
wolf.
hello argoldman, you would not by chance be interested in selling the engine?? I was looking for a midwest to put into my Varieze.
By the way diamond was bought midwest and they are making a single rotor with 50hp and 25kg (somehow expensive the want 13000€) end of the year they will have a 75hp single rotor.
wolf.
yes, guilty the VE is not in the US, but I will keep the N-numbers (much less hassle compared to I-XXXX) also should faith (work for a US company) bring me to the US during years to come... The ownership is claer, but the log's and the OL (basically al the papers disapeared, the 3rd owner died...) so I have to ask for a copy anyway.
wolf.
Ok thats good, who can get me a scan or a copy of these instruction??
wolf.
I need the FAA rules for the engine change, my Varie is US registered, Oreste is building with the Italian regulations.
wolf.
ok the 40h would be fine, but can I do that also here in europe, I am not going to ship the VE to the US for this. Whom do I have to ask and what form do I have to fill???
wolf.
But the engine weight my friends! The weight
wolf.
dear all, I am rebuilding a VE, has flown had a O-200, but I want to install something else, either Rotax 912 or a jabiru 3300. What are the rules, do I have to comunicate to the FAA the change do I have to do some test filghts (apart form the testing I will do my self obviously)???
By the way the craft is N numbered but we are in Italy.
wolf.
question, since I am rebuilding a VE, would it be possible to install the flush bellhorns also on the Varie?
wolf.
These Online translations are horrible, please next time you need a german-english and vice versa translation send me a message and I'll translate.
Diese Online Uebersetzung sind furchtbar, das naechste mal schickt mir eine Nachricht und ich mach das.
wolf.
Hi, anybody who can give me an insight on the rotamax rotary engines. On the paper they look good, light and powerfull, how about rael life??
thanks guys nevertheless I think I will mount the jabiru 3300, with up to 120hp, installed 83 kg and nearly 10inches smaller than the O-200 I should get a light and fast VE.
wolf.
chiama mi 3493569870 penso che ti posso aiutare
wolf.
Sirs I am looking for the prop station for a O-200 VE
wolf.
5$/gallon AVGAS that would be my joy overhere, I refulled last sunday here in Italy and I payed 2.4€/L that would be like 14$/gallon. I need the MOGAS..
wolf.
Dear all the question has surely been asked before (did not find it with the search function).
What is the best (max) prop dimension usable in a VE.
The VE & LE POH state 58 inch but it seems that most people have larger props (my Long, which I did not build has a 62inch Prop).
Now is the 58inch limit due to ground clearence or more to the max rev. Rutan wanted to run his prop??
wolf.
Lynn could you get me in contact with someone who installed a O-320 in a VE?
wolf.
Anybody who bought a jabiru engineand does not want to use it anymore. Would buy.
wolf.
Hi Lynn the 160hp sounds good but the O-320 is nearly 300lbs empty, that would leave me less than 200kg usefull load (overgross allready) and basically transform the VE into a one-seater. I had an Idea of using the jabiru 5100 which gives about 200hp weighing 257 pounds installed, that would be a rocket..
wolf.
hidden rudder bellhorns for the Varieze?
in VariEze
hello again, nobody knows if I can use hidden bell horns on the VE??
wolf.
