Steve Innova
394 -
2
Posts posted by Steve Innova
Dropping price to $300.
Sorry -- that should be "Everything except the Cleveland brake master cylinders have been sold."
$600 or best offer.
Carbon Fiber is SOLD. Thanks!
Yes, these were the brake/combo spec'ed for the infinity gear.
I'm not sure, I was building a cozy mk4. you would want to ask other longEZ builders.
Yes, it will work with mgs epoxy.
For the MGS epoxy, you can always test the pump ratio using small, equal size measuring cups. If the ratio is correct, you will fill two cups with resin and one cup with the hardener. You can test it using water first.
Not sure. The date on the Matco part diagram is June 2001, so it's on/after that date. If you are interested in purchasing them, I can see I can locate serial #s and you could check w/the factory.
Filipe - yes it's adjustable. Here's the description from the website :
The SS-180J mix ratios 7:100 to 29:100, the SSD-ADJ mix ratios 17:100 to 65:100. Replacement parts available.
http://aircraftproducts.wicksaircraft.com/item/tools-supplies/sticky-stuff-despenser/ssd-adj
For sale, brand new, unused "Sticky Stuff" epoxy pump: $125
(retails for $300 at Wicks aircraft - http://aircraftproducts.wicksaircraft.com/viewitems/tools-supplies/sticky-stuff-despenser )
** note ** the lid for epoxy reservoir seems have vanished, but can be purchased for $10.15 at Wicks.
For Sale: (2x) Cleveland master brake cylinder, model 10-54: $325 obo
(retails $363 each, http://www.aircraftspruce.com/catalog/lgpages/cleve-mbrk10-54.php?clickkey=121447)
For Sale, all new parts, never installed:(2x) Matco Wheel and brake assemblies (matco part # WHLW51LXT: $350 for both(these retail for $354.88 each, at http://www.matcomfg.com/WHLBRKASSYTRPLeXtraTorQ-idv-2375-33.html)
(2x) Matco Axle assembly A-1H model (This is modified axle required for the Infinity retractable landing gear): $50 for both
(retails for $62 each, at http://www.matcomfg.com/AXLEASSEMBLYA1A-idv-3762-1.html(2x) Michelin 5.00-5 6-ply tires (AC Spruce part #06-01214: $100 for both(these retail for $138 each)(2x) Michelin 5.00-5 inner tubes,(AC Spruce part #092-308-0): $75 for both(these retail for $78.95 each)(2x) Matco Remote Reservoir Kit (# MCR-100k): $50 for both
(these retail for $47.73 each, at http://www.matcomfg.com/REMOTERESERVOIRKIT-idv-2615-9.html)
(1x) Matco Flow Valve PVPV-1, parking brake valve: $75
(retails for $139 at http://www.matcomfg.com/PARKINGBRAKEVALVE-idv-2606-8.html)
Carbon Fiber still available, but the fiberglass is sold.
investigating export rules -- may not be possible to ship the carbon fiber.
For sale:
- RA5177 unidirectional fiberglass (RA5177 xx oz 38" wide) (40 yards): $200
- Carbon Fiber 282 bi-directional (3K 282, 5.6 oz, 60" wide) (10 yards): $200
- Carbon Fiber 716 un-directional (3K 716 5.0 oz, 38" wide) (20 yards): $400
** note ** I'm offering this at about a 50% discount. In particular, the Carbon Uni 716 is almost impossible to find now. I'll be posting this on ebay too, so this probably won't last!
For sale, MGS epoxy at about 50% discount:
MGS L285 resin (2 gallons) - $150
MGS H285F fast hardener (5 quarts) - $100
MGS H287S slow hardener (7 quarts) - $150
These have dates 2008 and 2012 on them, so they are somewhat old. But as I understand it, they don't actually expire as long as they are stored in a dark place, which they were.
Local pickup (Arlington VA 22205 only), as I don't want to deal with hazmat shipping.
Sorry, I don't have that info. I think it was built about 10 years ago. But never installed, packed very well, no corrosion - just oiled the exterior and re-packed it.
SOLD: Full Hardware / Metal Parts Pkg for Cozy MkIV - $850 or best offer
in For Sale (or for Free)
For Sale -- 90% of the Brock metal parts (and 100% of the expensive ones!) and probably most of the hardware required to complete a Cozy MkIV (bolts, nuts, rivets, flexible couplings, bearings, etc).
Brock parts are inventoried below - the AC spruce and Wicks hardware is not inventoried, but is all labeled & organized -- see the photo below, includes nuts, bolts, flexible couplings, rivets, etc...
Asking $850 for the whole lot or best offer (added all up, it's well over 2k retail)
Chapt: 9
(4x) MKMG-4 Bushing, Main Gear Mounting
(2x) MKMGA Spacer / Sleeve Assembly
Chapt 11:
(4x) NC-2 Hinge Insert
(6x) NC-3 Hinge Plate Assembly
(1x) NC-5a Pitch Trim Bellcrank
(2x) NC-6 Torque Tube End Plug
(2x) Hinge Jig
(1x) MKNC-12A Torque Tube Offset Left
(1x) MKNC-12A Torque Tube Offset Right
Chapt 12:
(2x) CNL Aluminum Bushing
(2x) CN2 Bushing
Chapt 15:
(2x) CS-72 Rudder cable pulley bracket 29 deg
Chapt 16:
(2x) CZSA Stick Assembly
(4x) CS-1A Pushrod threaded Insert, AL
(10x) CS-50 Pushrod Threaded insert
(4x) CS-108 / 117 Control System Bearing Assembly
(1x) MKCS124 L Control Torque Tube Bellcrank Left
(1x) MKCS124 4 Control Torque Tube Bellcrank Right
(4x) CS-181 Pushrod disconnect
(8x) CS-201 Bushing
Chapt 17:
(1x) CZRTH Roll Trim Handle
(1x) RT-2L Roll Trim Bracket Left
(1x) RT-2R Roll Trim Bracket Right
Chapt 19:
(2x) CS-128 Bellcrank Aileron Linkage
(4x) CS-127 Bracket, Aileron Bellcrank Linkage
(2x) CS-132 / 152 Bellcrank Aileron Tube & Bearing Tubes
(2x) CS-131 Spacer, Aileron Bellcrank Linkage
(2x) A2 Bracket, Inboard Aileron Hinge Mount
(4x) A5 Bracket, Outboard Aileron Hinge Mount
(12x) LWA-9 Bushing, Wing Bolt
Chapt 20:
(2x) Hidden Rudder Bellhorn
(1x) CS-301R Rudder Horn Right
(1x) CS-301L Rudder Horn Left
