toast Posted October 5, 2023 Share Posted October 5, 2023 My dragonfly has all steam gauges, and I'd like to upgrade the panel to something little more modern. Things I'd like to have A heading indicator An engine monitor A com radio with dual watch (a necessity in busy bay area airspace) The ability to add a Garmin GPS 175 later on I don't care too much about having an autopilot The panel won't fit a 10" PFD, but the 7" landscape g3x or dynon screen should fit. Between those two it seems mainly just a question of which interface I prefer. Is there anything else I should consider? Quote Link to comment Share on other sites More sharing options...
Marc Zeitlin Posted October 5, 2023 Share Posted October 5, 2023 41 minutes ago, toast said: My dragonfly has all steam gauges, and I'd like to upgrade the panel to something little more modern. Things I'd like to have A heading indicator An engine monitor A com radio with dual watch (a necessity in busy bay area airspace) The ability to add a Garmin GPS 175 later on I don't care too much about having an autopilot The panel won't fit a 10" PFD, but the 7" landscape g3x or dynon screen should fit. Between those two it seems mainly just a question of which interface I prefer. Is there anything else I should consider? In no particular order: Cost (Garmin is more) Upgradeability (Garmin has more flexibility and better integration of components, as long as they're all Garmin) Customizability (Dynon for the clear win here wrt UI) Support (Dynon generally wins here) If you're interested in future IFR, you WILL want a 2-axis autopilot (and if you're not, you certainly don't need the GPS175). With IFR, you'll also want a backup ADAHRS (either Garmin or Dynon can have dual ADAHRS's). But with only one screen, if the screen craps out, you'll need another screen, so rather than a 2nd ADAHRS for the single EFIS, you might consider a G5 which has a built in ADAHRS (and backup battery, if you buy one). If you use a G5 as a backup for the G3X, it can automatically take over driving the Autopilot. If you use a G5 as a backup for the Dynon, obviously it is completely standalone and cannot pickup A/P control. But you also have no common mode failures, since they're built by different MFGs. Lots to consider. 2 Quote Marc J. Zeitlin Burnside Aerospace marc_zeitlin@alum.mit.edu www.cozybuilders.org copyright © 2024 Link to comment Share on other sites More sharing options...
toast Posted October 9, 2023 Author Share Posted October 9, 2023 Thanks for the reply! Definitely lots to consider. It may be worth just slotting a G5 in for now doing the full IFR upgrade later since that'll likely take me quite a few months to get everything installed. Quote Link to comment Share on other sites More sharing options...
