Jon Matcho 54 Posted July 27, 2018 On 7/25/2018 at 9:19 AM, Kent Ashton said: BTW, Here is my #1 top building tip: When you finish with an epoxy brush, squeegee out the excess, put it on a paper towel on top of a piece of poly. Saturate with some MEK, roll it up in the towel and poly with a bit of the towel exposed to air and weight it with a brick. Next day you will have a brand new brush and you don't use a lot of solvent. ? I don’t use MEK, but tried that with Acetone last night. I just opened it up, expecting the paper towel to be stuck to the brush but NO, it worked perfectly! Thanks Kent! ? Share this post Link to post Share on other sites
