Steve Innova Posted May 31, 2017 Posted May 31, 2017 For Sale -- 90% of the Brock metal parts (and 100% of the expensive ones!) and probably most of the hardware required to complete a Cozy MkIV (bolts, nuts, rivets, flexible couplings, bearings, etc). Brock parts are inventoried below - the AC spruce and Wicks hardware is not inventoried, but is all labeled & organized -- see the photo below, includes nuts, bolts, flexible couplings, rivets, etc... Asking $850 for the whole lot or best offer (added all up, it's well over 2k retail) Chapt: 9 (4x) MKMG-4 Bushing, Main Gear Mounting (2x) MKMGA Spacer / Sleeve Assembly Chapt 11: (4x) NC-2 Hinge Insert (6x) NC-3 Hinge Plate Assembly (1x) NC-5a Pitch Trim Bellcrank (2x) NC-6 Torque Tube End Plug (2x) Hinge Jig (1x) MKNC-12A Torque Tube Offset Left (1x) MKNC-12A Torque Tube Offset Right Chapt 12: (2x) CNL Aluminum Bushing (2x) CN2 Bushing Chapt 15: (2x) CS-72 Rudder cable pulley bracket 29 deg Chapt 16: (2x) CZSA Stick Assembly (4x) CS-1A Pushrod threaded Insert, AL (10x) CS-50 Pushrod Threaded insert (4x) CS-108 / 117 Control System Bearing Assembly (1x) MKCS124 L Control Torque Tube Bellcrank Left (1x) MKCS124 4 Control Torque Tube Bellcrank Right (4x) CS-181 Pushrod disconnect (8x) CS-201 Bushing Chapt 17: (1x) CZRTH Roll Trim Handle (1x) RT-2L Roll Trim Bracket Left (1x) RT-2R Roll Trim Bracket Right Chapt 19: (2x) CS-128 Bellcrank Aileron Linkage (4x) CS-127 Bracket, Aileron Bellcrank Linkage (2x) CS-132 / 152 Bellcrank Aileron Tube & Bearing Tubes (2x) CS-131 Spacer, Aileron Bellcrank Linkage (2x) A2 Bracket, Inboard Aileron Hinge Mount (4x) A5 Bracket, Outboard Aileron Hinge Mount (12x) LWA-9 Bushing, Wing Bolt Chapt 20: (2x) Hidden Rudder Bellhorn (1x) CS-301R Rudder Horn Right (1x) CS-301L Rudder Horn Left Quote
