steve,s wings
just set up the wings so i can drill the spar.
after setting up a water level it looks like the wing fits the spar fine, but the water is off by 1/2" Wing tip low.
if i fix the wing so the water line 17.4 is right then i have the root of the wing a little lower then the spar 1/4".
can i build the plane with the wing tips 1/2" low ?
or do i fill the strake ?
Steve M. Parkins
i have drilled the top outer bolt hole, and have it snug.
i have lifted the wing tip so the water line is dead on the forward LE.
i can see a smidgen(3/16") of the wing sticking down past the spar root.
i think this is the best i can get it.
i will now drill the lower/outer and inner bolt hole.
PS. i had to grind out a little glass to get the nut on, any tricks to getting glass back in side the hole ? or will flox do it ?
Steve M. Parkins
