D. deSosa Posted November 25, 2009 Share Posted November 25, 2009 I have a 6" prop extension and crush plate made by Saber Mfg. for sale. This is the recommended heavier duty prop extension with a 7" diameter prop flange and crush plate for Lycoming O-320 and O-360 engines. It has the SAE-2 prop hole pattern (bolt hole center to opposite bolt hole center = 4.75"). It has been mounted but never flown. There are a few cosmetic scratches but otherwise it is in perfect condition. I'll take the first $275 offered. You can check current prices at http://www.sabermfg.com/ Quote Link to comment Share on other sites More sharing options...
Lynn Erickson Posted November 26, 2009 Share Posted November 26, 2009 I have a 6" prop extension and crush plate made by Saber Mfg. for sale. This is the recommended heavier duty prop extension with a 7" diameter prop flange and crush plate for Lycoming O-320 and O-360 engines. It has the SAE-2 prop hole pattern (bolt hole center to opposite bolt hole center = 4.75"). It has been mounted but never flown. There are a few cosmetic scratches but otherwise it is in perfect condition. I'll take the first $275 offered. You can check current prices at http://www.sabermfg.com/what size are the engine flange bolt holes? 0-320 and 0-360 are different Quote Evolultion Eze RG -a two place side by side-200 Knots on 200 HP. A&P / pilot for over 30 years Link to comment Share on other sites More sharing options...
D. deSosa Posted November 26, 2009 Author Share Posted November 26, 2009 Engine flange bolt holes are 7/16" as well as propeller bolt lugs. Quote Link to comment Share on other sites More sharing options...
Lynn Erickson Posted November 26, 2009 Share Posted November 26, 2009 Engine flange bolt holes are 7/16" as well as propeller bolt lugs.thats the odd size used on some of the 320''s. most 320's are 3/8". aerobatic cranks use this size. all 360's are 1/2" Quote Evolultion Eze RG -a two place side by side-200 Knots on 200 HP. A&P / pilot for over 30 years Link to comment Share on other sites More sharing options...
MikeD Posted January 1, 2010 Share Posted January 1, 2010 D. deSosa I have just sent a PM regarding the prop extension to you. Regards MikeD Quote Tell me and I forget. Show me and I remember. Involve me and I understand. Link to comment Share on other sites More sharing options...
