  • 1 month later...
I measured the size of my current gas caps and it was 3". These http://www.aircraftspruce.com/catalog/appages/lwsprlfc.php are 70mm, which is just a little under 3". Is it likely that my measurement was off by just a little and these would fit? Are the openings pretty much standard size?
Last question: we don't need vented gas caps because we have the fuel vent at the back of the plane above the passanger seat, right?
Roger,
I don't know about the link you posted but I saw you didn't get any (public, at least) replies to your post. I ahven't flown my long-ez yet but I do have some nice fuel caps that I would recommend to anyone. You must lift the tab and then twist it 90 degrees before the cap will come off,
They are a little more expensive, but in my case, my confidence in the cap more than makes up for the cost.
http://www.aircraftspruce.com/catalog/appages/aerofuelcaps.php
I have model C36L but A36LFF should work too. You can go for the locking option too for a few more dollars. Not sure that's worth it.
Phil Long-ez Project Milwaukee
Phil
Long-ez project
Milwaukee
do not use vented caps unless you want to have the fuel sucked out of the tank and leak all over the strake
Roger,
If you change to a different type of cap you will have to cut out the existing filler neck and bond in a new neck designed for the new cap. There is no standard filler neck.
If you have the original Rutan style gas cap -- the one where the cap engages a small rod running across the filler opening -- then you may just need to replace the o-rings. There is one large and one small o-ring in each cap. I have some of these and will send you a set if you PM me your address.
Kin
