JTest Posted February 25, 2008 Share Posted February 25, 2008 G'day all I have drafted up a set of Main Landing Gear Extrusion Drawings. Please note that I have included the CD Optional move of the 3/8" AN6-80A Main Mounting Bolt. I recommend that they be printed and the measurements are correct on your copies. I drew them full size so there should be no scaling issues, but you should still check. I recommend making three copies and then cutting two along the center line (the 1/4"). Then glue the cutouts onto the inside angle of your 2" X 2" X 1/4" extrusions (remember to make a right and left set). The easiest way to do this is to put the sides with the 3/4" lightening holes back to back (should form a "T" shape) and then glue the other sides. Use the third copy to insure everything looks correct. Please feel free to review, comment and share if you feel they meet your needs. I welcome comments. Thanks for all the folks that gave me the information so I could draw these up. It is my hope they will save somebody some time later. Jeff FWD Landing Main Bracket.pdf Rear Landing Main Bracket.pdf Quote Link to comment Share on other sites More sharing options...
