JuneBug Posted June 27, 2007 Share Posted June 27, 2007 Has anyone come up with a toe mechanism for the ground crew to use to get the aircraft in and out of the hanger? Some guys use ropes,duct tape, etc..theres got to be a better way.. Newbie Long owner.. Quote Link to comment Share on other sites More sharing options...
dpaton Posted June 28, 2007 Share Posted June 28, 2007 On a Long, I think the common thing to do is to pick up the nose and drag it, or build a dolly with a nice spot to put the nose into so you can push it around while it's grazing. The Long/Vari nose gear isn't all that strong, and I wouldn't dream of attaching a tow bar to it. My $0.02. Quote This is not a sig. This is a duck. Quack. Link to comment Share on other sites More sharing options...
Waiter Posted June 28, 2007 Share Posted June 28, 2007 There are two methods I use: 1) If I am manually moving the plane, I find it easier (and probably safer) to push the plane back-wards, slowly and gently. I stand in front of the canard, lift it just enough so I'm still supporting some of the weight (not balanced) then push back-wards. (Use caution, its possible to tip over back-wards if the mains come to a sudden stop and your not ready for it.) 2) At the hangar, all the EZ's (we shared with 4 other EZs) had a small 4 wheel furniture dolly under the nose. After I shut down in front of the hangar, I get my dolly and lift the nose, then rest it on the dolly. We painted lines on the floor to act as guides. as long as everyone stayed on their line, all the EZs could be moved around without worry of hangar rash. On one occation that I needed to be towed in from the runway after an emergency landing (valve in cylinder broke). I sat in the plane and held the rope with my hands. Waiter Quote F16 performance on a Piper Cub budget LongEZ, 160hp, MT CS Prop, Downdraft cooling, Full retract visit: www.iflyez.com Link to comment Share on other sites More sharing options...
mfryer Posted June 29, 2007 Share Posted June 29, 2007 On one occation that I needed to be towed in from the runway after an emergency landing (valve in cylinder broke). I sat in the plane and held the rope with my hands. Theres never a camera when you need one!! Quote Link to comment Share on other sites More sharing options...
