Zulu Yankee Posted March 8, 2007 Share Posted March 8, 2007 I have one of those pesky two-car garages with two single garage doors and a SOLID structure between them. The structure between the two doors is load-bearing, so no way of removing it. Could anyone tell me how wide the Cozy is at the strakes? Has anyone else solved this problem? I have seen references to the problem on the internet in old newsletters, but have not seen the solution. For the sake of aviation, I guess I could knock the garage down around the airplane, but I doubt that I will be able to sell that idea to the Mrs. 1) Dimensions? 2) Ideas? Quote I plan to procrastinate, but not now.... Link to comment Share on other sites More sharing options...
Waiter Posted March 8, 2007 Share Posted March 8, 2007 My garage in CA was like this. I made the center post so I could temporally remove it. I made special brackets for the top and bottom to support the post, and "U" shaped brackets to mount the two door tracks to the post. I would roll both doors all the way up, and insert a safety pin so the doors couldn't be lowered. I then removed three bolts, two on top and one on bottom. Pushed the post out of the way and presto, I could get the EZ in or out. I'll look around and see if I can find photos of the post and rigging. Waiter Quote F16 performance on a Piper Cub budget LongEZ, 160hp, MT CS Prop, Downdraft cooling, Full retract visit: www.iflyez.com Link to comment Share on other sites More sharing options...
