tomwms Posted December 17, 2006 Share Posted December 17, 2006 I have a Varieze with 0-200 . aircraft leads to right in cruse . left rutter is shimed to correct -is it possible that engine is canted too much to right? Quote Link to comment Share on other sites More sharing options...
lfrers Posted December 29, 2006 Share Posted December 29, 2006 Does the prop rotate perfectly on it's axis? I'm not an expert but to get a general idea if it's close or not, while the prop is mounted, place an object like a chair with a wooden broom handle on it close to one of the prop tips almost touching. When you rotate the prop the other tip should have the same clearance. BTW Mine leads right too. Aileron trim broke. Always use rudder trim and I loose a few MPH. Quote Link to comment Share on other sites More sharing options...
