matter Posted January 7, 2006 Posted January 7, 2006 Is there a difference between the wing of the Long EZ as opposed to the Cozy Mark IV? Or is the only real difference in the wider fuselage? Can the wings from one be used on the other? Thanks Quote
Marc Zeitlin Posted January 7, 2006 Posted January 7, 2006 Is there a difference between the wing of the Long EZ as opposed to the Cozy Mark IV? Or is the only real difference in the wider fuselage? Can the wings from one be used on the other? Thanks They are the same SIZE, but structurally different (to deal with the almost 50% increase in gross weight. They CANNOT be interchanged. Quote Marc J. Zeitlin Burnside Aerospace marc_zeitlin@alum.mit.edu www.cozybuilders.org copyright © 2025
Wayne Hicks Posted January 8, 2006 Posted January 8, 2006 Nat also said the wing root is slightly thicker too. Hence the need for that sliver of foam added just prior to hotwiring. Quote Wayne Hicks Cozy IV Plans #678 http://www.ez.org/pages/waynehicks
bhassel Posted April 29, 2006 Posted April 29, 2006 So you wouldn't wan to use Long-EZ wings on a MK IV but what about the other way around. Is there a down side to using a Cozy wing on the Long? Would it allow a higher gross weight? Bob Quote Bob Hassel Cozy Plans #749 Santa Fe, NM http://www.cozyworld.net http://www.hassel-usa.com
