FLYEZ Posted September 4, 2005 Share Posted September 4, 2005 N93RF LongEZ Constructed 3/27/88 Engine 0-320 150HP 1100 hours since overhaul Fuel capacity - 50 gallons 4 indididual ceramic exhaust system nose wheel dampener, heavy-duty brakes and gear leg heat shields, oil filter adaptor on engine by B&C, airframe: approx. 720 hours, Propeller: composite over wood core,-Catto 3-blade, 60" Dia. 78" Pitch, Navaid Autopilot, Airspeed, scaled with knots and miles per hour, red lined at 190 knots, Attitude Indicator - New, Altimeter, Rate of Climb - New, Directional Gyro with Heading Bug - New, Magnetic Compass, Outside Air Temp. Gauge, Engine Instruments: Quote Link to comment Share on other sites More sharing options...
Stdavis Posted September 5, 2005 Share Posted September 5, 2005 Where are you located and how much are you asking, any Pics, Steve Davis N7124L Quote Link to comment Share on other sites More sharing options...
FLYEZ Posted September 5, 2005 Author Share Posted September 5, 2005 Call the owner for more details: (630) 212-9009 Quote Link to comment Share on other sites More sharing options...
FLYEZ Posted September 13, 2005 Author Share Posted September 13, 2005 N93RF LongEZ Constructed 3/27/88 Engine 0-320 150HP 1100 hours since overhaul Fuel capacity - 50 gallons 4 indididual ceramic exhaust system nose wheel dampener, heavy-duty brakes and gear leg heat shields, oil filter adaptor on engine by B&C, airframe: approx. 720 hours, Propeller: composite over wood core,-Catto 3-blade, 60" Dia. 78" Pitch, Navaid Autopilot, Airspeed, scaled with knots and miles per hour, red lined at 190 knots, Attitude Indicator - New, Altimeter, Rate of Climb - New, Directional Gyro with Heading Bug - New, Magnetic Compass, Outside Air Temp. Gauge, Engine Instruments: Fuel gauge sight glass, left & right; fuel pressure gauge; oil pressure gauge; oil temperature gauge; cylinder head temperature gauge > Tetra II+4cht and 4egt; exhaust gas temperature gauge > (with shock cooling alarm system); Left Mag, Right Electronic Ignition. AVIONICS: Collins Com. VHF 250 TSO, NAV 350 TSO, Transponder with altitude encoder, two place intercom. LIGHTING: Position Lights, Strobe Lights on wing tips, Landing/Taxi Lights, Panel Lights. Flight Controls: Wrist Control Side Stick; one on Right Side. Stick Controls Roll Through Wing Ailerons, and Pitch Through Canard Elevator. Call (630) 212-9009 for more info. Pictures can be seen on EZ Squadron web site. Quote Link to comment Share on other sites More sharing options...
