swinn Posted August 29, 2005 Share Posted August 29, 2005 Decided to replace the extrusions on the firewall on which the engine mount is placed on the Long-EZ. The previous builder had drilled several non standard holes in this extrusion for a custom engine mount scheme that I'm not comfortable with. The old pieces are now removed. I'll be using a heavier engine than was specified in the plans (360) so I'm going to put in steel angle instead of the plans specified aluminum angle. I read in a CP 86 (Oct. 1996) article that at least one person had experienced cracking of the extrusions with heavier engines hung on the aluminum. 4130 was used as a replacement. Anyhow, the only way I can find to get 4130 angle is to make it out of 4130 sheet by way of a 90 ton bending brake courtesy of the local metal shop. Does anyone know if this is an acceptable practice? Should the metal be normalized after this operation? Would I be better off to weld up some angle from two pieces of flat 4130 and then normalize it? Thoughts appreciated. Quote --Scott LongEZ #159 Finishing & Engine install Blogged at: http://www.briansplane.com Link to comment Share on other sites More sharing options...
Fred N. Posted September 9, 2005 Share Posted September 9, 2005 I am also replacing the LEZ original mounts which held a souped-up 0-320. Aluminum is not good for heavier engines. I plan to use this new system designed by Art Bianconi: This subject came up awhile back. Please go to this site >>> http://www.computer-certainty.com/ >>> >>> and click on the engine mount button and see what you think of this >>> alteration from plans mount. Being a non-engineer it seems very much >>> better than plans mount. Should other canards (ie Cozy MKIV) >>> consider something like this to make a better mount? Post public if >>> you wish. >>> >>> >>> >>> Jim Brewer >> >> Absolutely. This is an excellent solution. Take a look. See what you think. Fred N. Quote Link to comment Share on other sites More sharing options...
Wayne Hicks Posted September 9, 2005 Share Posted September 9, 2005 The link didn't open up for me, but my suggestion would be to make the mount method identical to what the Cozies are using. My hangarmate is building a Long EZ with an O-320. He's happy with his modified Cozy mounting method. Quote Wayne Hicks Cozy IV Plans #678 http://www.ez.org/pages/waynehicks Link to comment Share on other sites More sharing options...
swinn Posted October 28, 2005 Author Share Posted October 28, 2005 Thanks for the replies. I've got the steel bent now and have asked a few metalheads about the bending, they say it isn't a problem. The 4130 steel angle should work good. I looked at my Cozy plans to see about copying that method of mounting, but my firewall is already in place and I would have to remove/rebuild it to duplicate the cozy method of engine mounting. Quote --Scott LongEZ #159 Finishing & Engine install Blogged at: http://www.briansplane.com Link to comment Share on other sites More sharing options...
