Paul Phillips Posted June 30, 2004 Share Posted June 30, 2004 Has any one Built the rg And how much are the lycoming io360's to buy are you able to adapt a turbo to them easily Quote Link to comment Share on other sites More sharing options...
CBarber Posted July 1, 2004 Share Posted July 1, 2004 Which RG are you talking about, the Cozy the Velo etc? Most Velocity builders chose the RG. I did not. All Cozy's have a retract front gear and Infinity Aerospace sells main gear retract systems for the Cozy. On both the Velo and Cozy, the retract add about $6k to the price, plus longer build times and the obvious complexity. There are a number of builders pages which illustrrate the process. Price on a Lyc new from Velocity was quated to me last year in the low $30k (200hp) range. Vans, may have them cheaper and I have seem them advertised from third party engine builders at about $20k. However, you hear of folks getting a mid time engine in the teens and a run out engine even lower. Price WAS a factor on me choosing a Mazda rotary. Comlete, it should be under $10k.......but, to many, an auto conversion is very contoversial. FWIW. All the best, Chris Quote Christopher Barber Velocity SE/FG w/yoke. Zoom, zoom, zoom. www.LoneStarVelocity.com Live with Passion... Link to comment Share on other sites More sharing options...
mtorzews Posted July 2, 2004 Share Posted July 2, 2004 This is the AeroCanard folder so I assume Paul is referring to the AeroCanard RG. The aerocanard RG is the same as the Cozy MKIV with a slightly wider backseat and a retractable main gear. There are several Cozy's being built with retractable gears. Check out Phillip Johnson's site. He's is one the biggest supporters of RG. http://www.maddyhome.com/canardpages/pages/plmjohnson/index.html But the designer of the plane Nat Puffer and many other builders are highly against retractables. Quote Mike T Link to comment Share on other sites More sharing options...
