mlefebvre Posted December 24, 2003 Share Posted December 24, 2003 I have been playing with a flight plan software package and I wanted to program a standard COZY MkIV into the software to model some flight plans. Could you guys provide me with the performance specs of the cozy AT GROSS for: Rate of Climb (Ft/Min): Indicated Climb Speed (Kts): Climb Fuel Burn Rate (Gal/Hr): Default Cruise Altitude (Ft): Cruise TAS (Kts): Cruise Fuel Burn Rate (Gal/Hr): Rate of Descent (Ft/Min): Indicated Descent Speed (Kts): Descent Fuel Brun Rate (Gal/Hr): Quote Tis far easier to ask for forgiveness than for permission. Link to comment Share on other sites More sharing options...
Marc Zeitlin Posted December 25, 2003 Share Posted December 25, 2003 Originally posted by mlefebvre Could you guys provide me with the performance specs of the cozy AT GROSS for: ..... Was the information at: http://www.cozybuilders.org/performance/ insufficient? Quote Marc J. ZeitlinBurnside Aerospacemarc_zeitlin@alum.mit.eduwww.cozybuilders.org copyright © 2023 Link to comment Share on other sites More sharing options...
mlefebvre Posted December 25, 2003 Author Share Posted December 25, 2003 Originally posted by Marc Zeitlin Was the information at: http://www.cozybuilders.org/performance/ insufficient? It provided some of the data points, but not all. I could not ascertain from your data: Climb Fuel Burn Rate (gal/hr): Rate of Descent (Ft/Min): Descent Fuel Burn Rate (gal/hr): unless this can be extrapolated from your data points, I wasnt able to determine these at gross weight. Marc Quote Tis far easier to ask for forgiveness than for permission. Link to comment Share on other sites More sharing options...
Marc Zeitlin Posted December 25, 2003 Share Posted December 25, 2003 Originally posted by mlefebvre I could not ascertain from your data: Nat's data - not mine. Those are scans of the standard COZY Owners Manual. Here's what I use: Climb Fuel Burn Rate (gal/hr): 13 gal/hr at full throttle (average - it's a bit higher at low altitudes and full rich, and lower at high DA's and leaned out) Rate of Descent (Ft/Min): Highly personal - descents can be anything from closed throttle slow descents to full throttle high speed dives, and anything in between. I use 500 - 700 ft/min for cruise descents at 220 IAS in smooth air, and 180 IAS if it's a bit bumpy. Descent Fuel Burn Rate (gal/hr): See above. I don't have a fuel flow meter, so I can't tell you exactly, but I'm gonna guess anywhere from 6-9 gal/hr. Since you spend so little time in a COZY climbing and descending (in comparison to a spamcan), the fuel flow rates in those modes don't make much of a difference in total fuel usage on reasonably long cross-countries. As an aside, you might want to ask this question on either the COZY or canard_aviators mailing lists, since there are a lot more people flying COZY's on each of them. It seems to be just me and Norm Muzzy around here...... Quote Marc J. ZeitlinBurnside Aerospacemarc_zeitlin@alum.mit.eduwww.cozybuilders.org copyright © 2023 Link to comment Share on other sites More sharing options...
