John Slade Posted December 22, 2003 Share Posted December 22, 2003 Bob Nuckolls posted the following to the Aeroelectric list and asked that it be passed around.... I think it contains some good points for general building as well as for the electrical system...... --> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <bob.nuckolls@cox.net> From time to time, a builder writes to ask, "I got a really good deal on this kind of wire, can I use it to wire up my whizzy-giget?" Or, "Why should I go out an buy this $high$ connector that takes a special tool when this $low$ connector does the same job and installs with a soldering iron?" I've been pondering this situation for the past several days. Indulge me please while I share some past experiences: When I was in the 4th or 5th grade, I shared an interest in model aircraft construction with a cousin about 5 years my senior. He worked in a hobby shop and I think took much of his compensation in store stock. His models were all beautifully crafted and flew well. I recall a conversation about glue. His personal choice was a product called Ambroid while my personal preference was for a less expensive, faster drying Testor's model cement. As I recall, Ambroid sold for perhaps three or four times the price of Testors. It also took 12-18 hours to reach full strength. When you considered the cost of a kit, cost of engine, and hours to assemble, and a quest of lowest cost of ownership (lots of maintenance-free flying), the difference in $total$ for assembling with Ambroid vs. Testors was insignificant. He also covered in silk while I used tissue. I suspect there were additional differences in our choice materials and techniques wherein I went the $low$ route . . . but in the final analysis made little difference in the total cost of our respective projects. Perhaps it was a mute point in my case, cousin Calvin's models usually lived to fly many a mission while my own were not so fortunate. Had any of his models survived to the present time, it's a certainty that they would be the finest examples of model construction of that era. Would we build a model that way today? Epoxy wasn't around then. Nor were any form of composite materials. You had to shrink coverings to contour with multiple coats of finish, not with a hot iron. Radio control was bang-bang, rudder only at wide open throttle, today it's fully three-axis with trims accessory control channels + throttle. I open my seminars with a statement to the effect, "You folks are building the finest airplanes to have ever flown." This always raises a few eyebrows, "Wha-da-ya- mean? I don't know all that much about it." I can confidently reply, "Yes, and that's why. You participate on list servers to tap the collective gray-matter of the OBAM aircraft community. You are attending this seminar to achieve a higher level of understanding. If you break something, it gets replaced. If a part doesn't work quite right, you rebuild it as needed until it does. Unlike those new graduates bucking rivets on an assembly line while dreaming about what they're going to do after work that evening, YOU are paying attention to achieving the very best the community knows how to do. I'll suggest there is more VALUE in a nicely built RV than ANY spam can irrespective of how nice the paint looks or what electro-whizzies are bolted to the panel. Finally, no two OBAM aircraft are built exactly the same way. Certified airplanes are literally carved into regulatory stone of conformance, your airplane can freely evolve. OBAM aircraft are by definition at the leading edge of performance and value in aviation." Remember the Jimmy Stewart movie "Flight of the Phoenix"? The folks trying to assemble a man-rated, flying aircraft from a pile of salvage were not pleased to discover that their "designer's" previous experience was limited to building flying models. It took some time for folks to understand that basic principals of structures and flight were interchangeable between the worlds of miniature and full-scale. I suggest that after you've purchased kit, engine, propeller, brakes, and a panel full of whippy radios and instruments, impact on total cost for the-best-we-know-how-to-do versus materials or tools you discovered at a garage sale or hardware store is trivial. My experience at workbench of cousin Calvin stands out my memory as a benchmark of Calvin's superior sense craftsmanship. He chose to build in a manner that represented the very best the model building community knew how to do. To be sure, few OBAM aircraft builders are going to be using today's techniques and technologies 20 years from now . . . May I suggest we should be wary of tools, techniques and materials popularly used 20 years ago? May I further suggest that it's not so much a question of "will it work" as opposed to will it be something you'll look back on 20 years from now as the best we knew how to do today? Dee and I offer our best wishes for you and yours for the upcoming holidays. We're looking forward to meeting many of you in what promises to be a busy seminar schedule for next year. It's always enjoyable and gratifying to work with folks building the finest airplanes to have ever flown. Bob . . . P.S. I'd appreciate it if folks would take the time to relay this note to other list servers . . . Quote I can be reached on the "other" forum http://canardaviationforum.dmt.net Link to comment Share on other sites More sharing options...
Jim Sower Posted December 22, 2003 Share Posted December 22, 2003 I was going to post it in the Cozy list .... Quote ...Destiny's Plaything... Link to comment Share on other sites More sharing options...
