dust Posted June 2, 2003 Share Posted June 2, 2003 Minor tweek thought here, a square crosssectoin is more effecient than a rectangular one for airflow (so says largeprime), how about making the heat duct the same width as height? Quote maker wood dust and shavings - foam and fiberglass dust and one day a cozy will pop out, enjoying the build i can be reached at http://www.canardcommunity.com/ Link to comment Share on other sites More sharing options...
dust Posted June 8, 2003 Author Share Posted June 8, 2003 We are using an electric air brake actuator and today I removed the plans pivot point for the manual deploy system, if you plan on using the elec actuator, don't put it in, saves weight, he he he Quote maker wood dust and shavings - foam and fiberglass dust and one day a cozy will pop out, enjoying the build i can be reached at http://www.canardcommunity.com/ Link to comment Share on other sites More sharing options...
