John Slade Posted July 4, 2002 Share Posted July 4, 2002 For those who haven't done the upgrade yet, here are a few tips... 1. Saw about 3/16 off each MM4 to get the same length. There is still plenty of thread in the insert. 2. The rod end inserts are hard to tap. Not a place to have weak threads. Be prepared to have an expert do it for you. 3. Drilling the wide washers is easy, but you really need a drill press for the bellcranks. 4. You'll need eight AN4 7A bolts, matching MS21042-4 nuts and ten stop nuts for the mm4s. 5. Watch out for clearances - things that touch now that didnt before. Quote I can be reached on the "other" forum http://canardaviationforum.dmt.net Link to comment Share on other sites More sharing options...
