JTest Posted December 28, 2008 Share Posted December 28, 2008 G'day I am looking for some .pdf drawings of the parts that need to be made for the elevators. I have started the chapter, but can't finish without any drawings to make the attachment parts and lead weights. If anybody has plans would you be so kind to post them? Thanks in advance! Jeff Quote Link to comment Share on other sites More sharing options...
rickh Posted December 28, 2008 Share Posted December 28, 2008 Assuming your elevators are the same construction as the Cozy-IV... I have the Aerocanard shareware PDF of the Chap. 11 instructions, if that'd help. It does show most of the dimentions. No weight for the counterbalance lead though. I found, as have many others, you should buy [most of] the parts from the Girrrls. Spool pieces and hinge inserts specifically. I'm sure they'll suggest buying more than just them though Rick Quote Rick Hall; MK-IV plans #1477; cozy.zggtr.org Build status: 1-7, bits of 8-9, 10, 14 done! Working on engine/prop/avionics. Link to comment Share on other sites More sharing options...
