458 -
Posts posted by mfryer
Correction: Any ref to 0.04" mentioned above should read 0.4" (4/10ths). But you guys are ready knew that! Sorry for the typos.
Hat
Ref: Long-EZ plans change #45 CP27. http://www.cozybuilders.org/ref_info/Canard_Pusher/LongEZ_Plans_ChangesUpdate.htm
Thanks for the input. It will take me a while to wrap my head around all of that.
Also thanks for the complement, however folks out there should be aware that if there is the illusion that my work is somehow great or good, it is only due to the fact that my garage floor has a 1970s pattern that causes the brain to adjust its sense of taste and could alter ones perception of the quality of other objects in the vicinity.
too..... to.... respond
I am about to skin the outside of the fuselage. However it has been suggested that I might install the rudder cable conduit through the side foam. My primary reason for this is to avoid having to drill a hole through the landing gear brackets.
However after discussing this with my brother I am having second thoughts. Mainly what I am about to do is a departure from the plans and it involves a control system, so I am a little shy about it.
Also I saw this clip on
, about a third of the way through it shows some nifty rear seat rudder peddles. I do not see how this could be accomplished if I ran the conduit through the side foam.I bought a long 3/16" bit and drilled from the inside just behind the rear landing gear pad forward as seen here. More photos can be seen at http://flyingbackward.blogspot.com/
Flying Backward
Any thoughts or suggestions????
I buried my rudder conduit in the wall of the fuselage. It makes for a fairly straight run.
Let me know if you need any measurements
If there is a real advantage to installing the rudder conduit on the outside I am definitely interested in measurements or photos if you have any.
I did not drill the holes in the larger landing gear brackets for the conduit because I had read of a failure possibly cause by that hole. If routing the conduit through the side foam solves this I will try it out. Thanks.
I am pretty much done preping the fuselage exterior for glassing. Before doing so , does anyone have any suggestions i.e. antenna, electrical, rudder conduit etc...
Flying Backward
Thanks. I now see two challenges in my future. One is to have an aircraft nearly as beautiful as those on your site.
The other is to have less gray hair by the time it is complete. (I have a start, but if I strain hard enough I might be able to hold back additional gray).
I suppose I should also be happy just to have hair if there is any left as well.
Very nice looking Long-EZ. Do you have any more pictures???
I got my set back in August???. It had 3 CDs. I was told a fourth with some additional CPs and photos would be available soon, but it did not sound to me like it would contain any really necessary information.
I saw the episode. I agree the question was quite silly. What really surprised me was that the ultra-lite pilot was expecting a different result!
If its tech jobs you are looking for, the Pacific northwest might be a choice. But for flying.... you better get your instrument rating!
Can anyone be so ignorant about simple physics that they actually need to 'bust' this myth?
"can a plane take off on a conveyor belt"
Perhaps you could elaborate?????
Interesting. It has a conventional steerable nose wheel.
Just a couple of comments....
What is the source of the interesting colors. It appears that perhaps the dark brown is where you peel plied?
You cut off the tabs in the lower corners of F-22. Is there a reason for this?
Also I can't really tell from your photo if you did this, but there is an optional change in the CP newsletter 27 that suggests "Revise F28 bulkhead by moving the longeron notch down 0.25". This raises F28 for better fit to canopy."
Or you could just resign and join us here in bizarro world and become left handed.
The Long-EZ plans call for Cleveland wheels. However I recall recommendations that the brakes could use some improvement. Also it would appear that Grove offers some wheel/brake options that might work for the Long-EZ. Any suggestions?
Wahoo! I can finaly contibute something useful
www.atkinsonfuelgauges.com/
nostromo56 at tx dot rr dot com
I mailed a check, got the gauges 5 days later.
Rick
Awesome! Thanks for the link! I was at first going to go with the plans method but I am using EZ-Poxy which has a pretty yellow tint to it and I don't think the resulting gauge would be very readable.
I also would like to have a couple of electrical gauges, but do I understand corectly that it can be difficult to find a location for them?
Rick
They're made by Vance Atkinson. Here's his web site: http://home.comcast.net/~nostromo56/
That link is now dead. Does are these sight gauges still available?
When I started my project I thought it would be fun for my son to work on it with me. Unfortunately it is a little difficult to teach him while I am still learning so much of the process myself. Still I have him sanding some parts, measuring twice and he has made a couple of console panel prototypes. He really likes to help when I am not up to my elbows in epoxy.
If you want the best of both worlds, install a water resivoir, a windshield washer pump and spray heads over your head. When your brain gets to the groggy side, give it a shpritz!
Sorry, couldn't help myself...
You asked for advice...
Advice one: Forget the webpage. Build instead. Theres a lot of guys with embarrassing webpages.
Wow, I hope mine is not embarrassing. However I do understand that updating the web page can be time consuming. I prefer to work on the plane.
Still I use a blogger account that make updating the page quick. My primary purpose is to keep my brother and a few other interested parties up to date, but hopefully a side effect will be to warn others not to screw up like me.
...hhhmmmmm....
I did a quick search on the NTSB database for IVO prop and found only 4 reports between 1/1/89 and 5/18/2004. 3 were engine failure and one was a Darwin award to the pilot. None were prop failures. I've been seriously considering thte IVO prop but now you've got me worried
I think it was Socrates who came up with the three point plan for passing on rumors 1) do you know it to be the truth? 2)is it derogatory? 3) does it benifit me to know?
Can anyone point me to some facts about the IVO prop?
I just have to wonder if the IVO prop company has anything to say. Sure a person should use caution with any information provided by stakeholders on that side of the fence, but they would probably have some insight into incidents involving there products.
External rudder conduit.
in Long-EZ
My main reasoning was to avoid drilling a hole through the landing gear bracket. The route through the exterior would be nearly as strait as per plans. At this point I do not think I will run the cables through the outside, but I might install the conduit there now just so I have the option at later date.
As far as the slurry. The CPs state pretty clearly that ALL foam should be slurryed. The video shows slurry on both types of foam as well. It does not sound like there will be a catictrofic failure if it is not slurried though.
