61 -
1
Posts posted by karoliina
Both rolls and loops work fine in the X-plane model of Cozy
allthough the loops build up lots of speed.
But I was thinking how a canard would be able to do
aerobatics then (if we are thinking of a "Super Cozy" in other
words something that is a step further):
- for inverted flight: better pitch control that has authority
even in inverted flight
- aerodynamic design should allow a higher Vne. The 220 mph
Vne is very low considering that many Lancairs have higher Vne
and even higher cruise speed. As a result, the speed build up in
a loop wouldn't be that big problem.
* can someone point out why Cozy's Vne is just 220 mph, in other
words, what breaks if one flies overspeed? Airplanes that have less
strong structure have sometimes higher Vne and it makes me wonder
what is the problem with Cozy. With X-plane model, it is possible
to fly several times faster than Vne without aerodynamic problems.
But that is another thing, when the control surfaces etc. tear of.
Is the 220 mph conservative Vne, the fastest speed Nat was willing
to fly in test program or is it really the top limit where after that the
aircraft tears apart?
* I can assume that the Vne becomes a problem with the prop first
(I assume it tears apart before the structure).
* About the deep stall issue: in X-plane model the Cozy does not
deep stall if the CG is on the right place, no matter how it is flown,
inverted, straight up etc. anything goes. When the nose is pointed
straight up and the airspeed becomes zero, the nose just drops
either forwards or backwards and it is possible to recover the aircraft
after that rather easily. It would be interesting to know why
this does not match with reality, in the case in reality, if the aircraft really
always goes to deep stall if flown like that.
Canard itself shouldn't be directly indication that aerobatics is
impossible since many fighter jets have indeed canards (double delta
wings) such as Saab Draken (okay Draken was not good aerobatics plane
or dogfight plane) and the newer Swedish designs. People are always
suggesting a slow turbulent profile aircraft for aerobatics, but jet fighters
for example aren't that slow despite they allow aerobatic maneuvers
in dogfight. What I am thinking would be an aircraft that has
handling qualities similar to a fighter jet. It would be possible to fly
inverted etc. with no problems with very high speeds.
I think that capability (whilst not being ideal) for basic aerobatics would
be a safety issue too. What if you end up in the trailing vortex of a 737.
Next you say that it will never happen. But errors can happen in
real life, even if you don't do any error, someone else can do it (and
you can become the victim), and one should never say never.
If you end up upside down with an aircraft
that has no control authority to roll it back would be a very hazardous
thing and in my opinion, the control surfaces should be designed so that
in emergency situation at least, it should be possible to recover the
aircraft from ANY position (it should be designed so that it would be
possible to break away even from deep stall if that would occur, in other
words, if main wing continuously stalls, it should be possible to make the
canard stall first in an emergency situation temporarily).
Also a "super cozy" should have a ballistic recovery system to save
the aircraft and pilot in the case it would enter unrecoverable deep stall
if the deep stall issue is so serious as some claim. I was thinking that
instead of placing the ballast to nose, it could contain the parachute
(another good reason for the placement would be avoiding hitting the
propeller).
- 1
I would vote for Burt Rutan, in addition of doing great
aircraft designs, he is now making my dreams come true
[with SpaceShipOne and the projects that will follow after
that and also in the sense of showing to people that it can
be done, which is also very important], it is a different thing to do
spaceships than build bridges. Yes, there is complexity in
bridges and railways, but space is a completely different
issue. There is also complexity in software and also in many other
areas of engineering. But still, it is still a completely different thing
to build a spaceship than write 5 million lines of C-code.
Burt Rutan is opening the final frontier for us, he appears to believe
in the same way as I do, space is a place, not a program.
I see no bright future for NASA, the future is in the commercial
utilization of space.
To get back to the original issue;
What comes to Super Cozy, I think that it would be a great
idea to try to improve the design if possible - in the case if
someone competent enough could do it, meaning that the
person has enough experience in aerodynamic design. There is no
perfect design out there and there is always room for improvements.
In the case of Cozy, I would see as the most important issue
the alternative engines. Old aircraft engines (meaning Lycosaurus)
really aren't very economic and also it would be a good idea
to increase efficiency by reducing weight, by reducing aerodynamic drag
(in other words perhaps laminar profiles to all wings) and
also what I have tried with the X-plane model, with a higher power
engine, why Cozy couldn't be basic aerobatics approved, perhaps
it would be very nice change. Aerobatics approved doesn't need to
mean that it would be inefficient aerobatics plane with turbulent
profile wings, but rather an aircraft that would allow flying upside
down etc. without problems - in other words, without being perfect
for the aerobatics task, would at least allow doing it if the
pilot can do it. At least the X-plane model does
barrel rows etc. basic aerobatics without problems, why it would be so
impossible to have a version of real Cozy that would allow that as well.
Wasn't the airframe designed for very high G loading after all, actually
for even higher loading than the actual aerobatics planes?
Also I would like more clear canopy (at least bigger windows)
so that also back seat would have excellent visibility to all directions.
For example some sort of that way than it was done in the
Opie-3. And of course, I would prefer that the Super Cozy or whatever,
would fly faster than a fastest Lancair out there.
Hi,
I by the way experimented with the X-plane model yesterday.
If the weight would remain the same, but the motor would
give 260 hp instead of 180, it would be a great aerobatics
plane. At least the model can do many kind of tricks and didn't
indicate any problem.
I also tried to get it to deep stall, but it just didn't go. I moved
the cg as much back as possible, but still it did not deep stall.
Finally I got it to a sort of backwards spin where I got out by
putting the motor to full power (I had modified the model to 350 hp,
so it appeared to be powerful enough to do it, I tried it also with
105 hp and it wouldn't have been enough to get it out).
I will try to modify the aircraft
in the editor since I would like to demystify what is the deep
stall on the first place. How about removing the lower winglets
in addition to moving the cg? Perhaps adding some overweight
and a underpowered engine?
Actually X-plane is pretty fun to try to find out what happens
if the builder does something wrong in the building process, assuming
that it is accurate at least to some extent.
Best Wishes,
Karoliina
That is an absurd claim. I fly my COZY MKIV into 3000 ft. runways that are 40 ft. wide with a 15 Kt. crosswind all the time, and have 500-1000 ft. to spare, both on takeoff and landing. It's hard to believe that all runways in Finland are shorter than 2000 ft. and narrower than 40 ft. - it would be very difficult to get scheduled airline flights into fields that small.
There is no scheduled airline traffic to those airfields.
Those where the airliners land, are of course bigger, usually
kilometers long (1 km = 1000 m ~ 3000 feet).
However, to fly around the country, I would like to land
to airfields that have no air traffic control and that are narrow and
short, just to visit nice places around. Still, in general they are longer
than 2000 feets and wider than just 40 feet except some exceptions
where it is not possible to land with a Cozy anyway (grass fields
and such).
That guy just believes that Cozy is very hard to fly and requires
lots of experience of high power aircraft.
But he is just that kind of guy, not only was
the question about flying, but the other things too.
He have also been trying to discourage me from starting the project,
he is pretty convinced that I just can't do it and I will waste
my life, health, money, time and whatever if I start.
Hi,
We tried it yesterday. One Finnish Cozy owner warned that Cozy
is very hard fly and land and that I could not land it to even
the biggest airfields in Finland.
Either the X-plane model is very inaccurate or his claims are wrong since
we successfully landed the virtual Cozy yesterday just with first try.
I had set wind to 8 knots and added some turbulence, but no
problem. In fact the airplanes I am currently flying, require a lot
more attention in the landing or otherwise the nose gear will
fail. Because I have never tried a simulator that would be completely
realistic so far, I am a bit sceptical, it just can't be that easy
in real life I guess or is there some unset realism settings in the
X-plane (hopefully it is not in a sort of arcade mode or something,
perhaps someone can assist me if he/she has better knowledge how
to put all realism on in X-plane if there is a such setting).
Best Wishes,
Karoliina
I am planning to build an airplane that is capable of flying 1100 nm nonstop. It has to have resonable low operating cost and preferably a diesel or turboprop powerplant.
Diesel is a good idea (IMHO). If I am going to build, that
is something I will consider.
Gas is expensive here!
Yes, exactly the same problem here,
I think it is even more expensive here in Finland...
Best Regards,
Karoliina Salminen
Hi,
Short introduction:
I am currently working as
senior software engineer / project manager at Nokia.
I can't tell much more about it except that my work somewhat
involves open source stuff.
My partner (who is also flying)
has a company which does pretty nice embedded Linux devices
based mainly on PowerPC family microprocessors. Those
would be quite suitable for EFIS systems, in the case someone
would be interested in Linux based avionics system. For more
information, have a look: http://www.katix.org
I have currently European UPL license (eligible to fly airplanes similar
to U.S. Sports Plane category) but I am going to upgrade
it to PPL in the future.
Currently I am flying TL-96 Star ( http://www.tl-ultralight.cz ),
EV-97 Eurostar and Ikarus C42. Despite of the variety of types of
aircrafts I am flying, I am currently a very low time pilot as I just
recently got the pilot's license. But that
is going to change in the near term future, as I am spending as
much time up there as possible
I am looking forward for someday perhaps owning a canard aircraft,
either purchased or self-built. Plans built aircraft could suit me better
than a fast build kit as the expenses would be quite much lower for
a plans built kit allthough it would consume more time and on the
other hand, I would prefer to spend more time on the air than in the
carage if possible but really, a plans built could be nicer to my bank
account (especially taking in account that I would need to pay
VAT + customs + overseas shipping expenses for a fast built kit
such as Velocity).
If there would be someone else from Finland (or nearby in Scandinavia)
and building/interested in canard aircrafts, please send me an e-mail and
tell me about your project. I would of course like to get a ride on
a such aircraft before proceeding to the decision to build.
Best Regards,
Karoliina Salminen
Hi,
Short introduction (haven't told before, I just came to this forum):
such as Velocity).
Best Regards,
Karoliina Salminen
Quote:
>In fact, my proposal would be on the other hand, more like
>ultralight Long-EZ combined with Starship features than IBIS.
I think this is a very interesting idea, but would like for the seating to be side-by-side instead of as we have with the Long-EZ and Ibis. Who's got the CAD system?
I wish it would be that easy...
Anyway, if someone has that knowledge (about aerodynamics),
I think it would be a great idea.
Here is the list of wished specs:
- 450 ... 550 kg TOW
- max 285 kg empty weight (excluding fuel)
- all composite design
- buble canopy
- two seated, preferably side by side
- Starship-style flaps
- stall speed with flaps max 65 km/h
- stall speed without flaps can be higher
In EU the IBIS could fit into ultralight b category if
the stall speed would be lower. There is no top speed limit
for ultra-b class in EU and therefore the top speed is no problem, only weight and stall speeds are. In order to fit into that category, IBIS should be modified perhaps so that it would utilize flaps (similarly to
Rutan's Beech Starship), otherwise the 65 km/h stall speed
will not be met (all other ultralights do it similarly, they normally stall at higher speeds, but with full flaps the speed have been able to lowered to the required range).
In fact, a modified IBIS that would be composite instead of wooden
design, and would utilize flaps similar to Beech starship and would
have empty weight under 285 kg, and would use 80 hp
Rotax 912ULS engine would be quite nice. If someone can accomplish that, I think there
would be many many builders out there thorough the Europe.
Rotary modifications
in Auto Engine Conversions
Interesting talk about tax deduction since I live in a country with insane gasoline taxation and therefore gas in my country (Finland) is very
expensive.
Yesterday the car fuel was cheap, I refueled my car and the fuel
did cost 1.102 euros per liter. 1 gallon = 3.79 liters.
Euro is about 1.26 USD. Therefore we can calculate how much it did cost
with your terms:
3.79 * 1.102 * 1.26 = 5.26 USD per gallon (and I consider it cheap).
AVGAS is becoming more expensive and it's price is expected
to increase by 100%. What if a gallon would cost more than 10 USD?
Your friend used 100 gallons per day gas, how he would liked if
that would have costed for him 1000 USD per day? Yes, that indeed
is going to happen in Finland.
Because of the high gas price here, I am especially interested in
alternative engines to Lycosaurus. Lycosaurus produces a very little
power compared to its enormous thirst.
Also, because of this, using an aerodiesel engine would be a very good idea
too except that the aerodiesel motors are very expensive (purchase price)
if compared to a auto motor running on gas (such as the RX7/RX8 motor).
