Jack Morrison
162 -
1
Posts posted by Jack Morrison
Lynn
Learn the process, it will give you very consistant , strong and light parts. It is not hard to do and I feel the benefits by far exceed the small cost of material. I have a high vacuum system I use but the low vacuum sysem the C Girrls use is also very effective especially for small parts. It is simple, low cost and very effective. I use it on all glass and carbon fiber I do now.
Jack
E Racer 113
Add a little width, round the fuselage and bingo.
Jack
E Racer 113
I must agree with Joe , the E Racer support has not been very good. I was also told when I was building my E Racer, that I should not have a problem if I had built a long ez. Unfortunately that was not the case. I must say in defense of Shirl, He designed a great aircraft. I am totally pleased with the end result but getting to where I am at know has taken quite a few years of individual R&D. I believe there are only about 5 E Racers flying and that is a shame, hopefully someone will take the project on and continual its development. Flying the E Racer is a star event.
Jack Morrison
EW Racer 113
I agree with Jon and Mark. The wings are straight, why a dihedral canard, just does not follow any form as I see it.
Jack Morrison
E Racer 113
Len
I have an E Racer, would it be possible to get a chair or two if I send you a inflight color picture? Very nice merchandise. email me at n345jm@comcast.net or call me at (630) 688-1295 cell - home (630)907-2040
Thanks
Jack Morrison
To set the record straight:
In 1996 I originally installed an all aluminum supercharged 300 hp V6 chevy in E Racer 113 in the mark 1 location, behind the cockpit seat, running a driveshaft to the rear of the AC coupled to a marine reduction drive unit. This engine produced 287 hp at 3600 rpm and was a great engine for the AC. The only problem I had with this engine is the radiant heat generated by the exhaust manifolds running alongside the upper longerons, burning paint on the center cowling and onto the top of the strakes. It got so hot that when Shirl Dickey was test flying the AC, it was softning the main gear fuse holders and popping out the fuses. It was a good thing I had designed a manual drop lock
for the main gear, there were no plans system. Shirl spent about 10 days with me trying to resolve this issue with absolutely no results to control the heat in the cowling. Shirl tried to make it to Oshkosh in 1996 but had to turn around about 10 miles out of ARR. I asked Shirl if I could install the Chevy engine aft of the firewall and he told me no because of the plans called for a aviation engine behind the firewall. I should not have listened, the Chevy with the supercharger complete less the redrive weighed in at 365lbs. At 4200 rpm develops over 300 hp. My SEFI540 LYC weighs over 500 lbs. but develops 380hp. I did not feel the mid-engine setup was safe and decided to pull the Chevy in 1996 and spend the next two years installing the IO540. I spent another two years developing the automotive supercharger to adapt to the LYC. engine. I sold the Chevy engine to another E Racer builder in Florida, he is mounting it behind the firewall with a bolt on redrive. In my opinion, this is where it should have been all along. Dont discount the Chevy V6 as an engine option, it performed well and was smoother than the LYC.
Heres what I changed on the LYC engine. I had lycon 3angle grind the valves on new TIO540 cylinders and flow match the heads, and balance all components. Stock 8.2 pistons and special cam grind on the cam. I installed a programable automotive EFI system (F.A.S.T.), an automotive throttle body, 2 Jeff Rose electronic ignition systems, two electric fuel pumps and a Vortech automotive supercharger. After many trial and errors, I finally reached my objective. I completely understand what John Slade is going through turbocharging his rotary. The superchargering answers I was getting from the (experts) in the field did not apply to my application. Very frustrating. Trial and error, trial and error, and I finally found the solution. Here is what I get. I am running a 64/113 three blade Catto prop. I do (not) have a wastegate. I control HP and MP with throttle . At 2000 rpm, 40 MP, alt 760, I can take off and climb out at 1500 fpm. The higher I go, just add more throttle, increases Mp, increases Hp, maintains rate of climb. At 10000 36 MP at 2950 rpm. That should give me SL pressure at 15000. Very fast. This prop is new and I have not finished my testing yet but should see great results. The only time I have pushed this engine at low altitude was leaving RR this year. Low approach at 275 mph, 2910 RPM,57 in Mp, climbed out at 5400fpm to 6000, 3200fpm to 8000. I would not think of changing this system,and if you do not push the system, It will never cause detonation.
Jack Morrison
Dale
Thanks, I'll need plenty of that running in unlimited.
Jack
The only complete aerodynamic position for all the gear is in the fully retracted position. Less drag, more speed, and much much better looking, but thats just my humble opinion. Some people are just never satisfied.
Jack
All I have to say to that is you must be reeeaaly smoooth. Good luck on the retracts.
Jack Morrison.
Frank
I just happened to run across this thread. Glad to see your engine problem is solved. Gosh , I wish we were all as intelligent as Dale. life would be so simple. Changing the subject, we met at Dayton at the cup race. I had the race in my pocket and could not find my pocket. I have the E Racer, you know, the one with all the problems. I sure hope they still have the race planned for next year, I will be ready. I made it to RR this year for the first time and had a great time. The canardians are great people. Drop me a line if you get a chance to hear the rest of story at the last cup race.
Jack Morrison
E Racer 113
Glad to see you going for retracts. They are more work and more maintenance but definately worth the effort. A picture is worth a thousand words.
Jack Morrison
E Racer 113
Thrust angle for 200HP
in Long-EZ
I have an E Racer with a sio540, thrust angle is the same as an E Racer with a O320 or an IO 320. Works perfect. 360 HP V 160 HP.
Jack
