mfryer Posted January 27, 2009 Posted January 27, 2009 Yesterday I cracked open my latest can of ez-poxy hardener. It was quite a bit lighter in color, (light yellow as opposed the the dark brown). It also was not nearly as smelly as the darker hardener I have been using. It also came in a smaller 1/2 gallon can as opposed to the regular half filled 1 gallon can. Has anyone else happened across a lighter, ez-poxy hardener, or heard of any changes to the formulation? I used it to lay up the 4 plies bid on the inside of the NG-30s and it seemed to perform identically to the darker stuff. Quote
Lynn Erickson Posted January 27, 2009 Posted January 27, 2009 Yesterday I cracked open my latest can of ez-poxy hardener. It was quite a bit lighter in color, (light yellow as opposed the the dark brown). It also was not nearly as smelly as the darker hardener I have been using. It also came in a smaller 1/2 gallon can as opposed to the regular half filled 1 gallon can. Has anyone else happened across a lighter, ez-poxy hardener, or heard of any changes to the formulation? I used it to lay up the 4 plies bid on the inside of the NG-30s and it seemed to perform identically to the darker stuff. it just new. thats the way it is suppose to be. the hardener gets darker with age after it has been opened. Quote Evolultion Eze RG -a two place side by side-200 Knots on 200 HP. A&P / pilot for over 30 years
