KeithO Posted December 12, 2007 Share Posted December 12, 2007 I recently wrote to Eco motors, a company in Germany who are building complete 80 and 100hp engine packages based on an automotive turbodiesel engine. The engines are 4 cylinder turbodiesels with common rail injection, along with the automotive style ECU. Both engines are 1.4L with the difference being the boost level (2.0 vs 2.4 bar) Drive to the prop is via a geared reduction drive with its own independant oil bath and 1.67:1 reduction. In the photos the reduction drive looks rough, but it may be the prototype version. Certainly, getting in the air with an experimental aircraft with an experimental engine is a big deal in Germany. I lived there and investigated this subject at length. Even if I had built a plans built (or even a kit airplane) I would have to do a static load test on all flight surfaces prior to getting an airworthiness ticket. Picturs of this process can be seen on many of the home pages of the German homebuilders. The web page is here: http://www.eco-motors.com/Index.htm Technical info here: http://www.eco-motors.com/Products.htm Contact details here: http://www.eco-motors.com/Contact.htm In their current offer, found here: http://www.eco-motors.com/images/Downloads/Eco-Motors-General-Info.pdf they are asking <10k Euro for the 80hp motor which contains the following: Basic Engine Kit Base aluminum diesel engine, common rail injection system, fuel pump, fuel filter,electronic control unit, reduction gear unit, turbo charger, air intercooler (Eco-100 only), oil reservoir, engine wiring harness, all sensors, device to readout and erase engine diagnostic state The 100hp version adds the intercooler and takes the price up to <12k euro The holding company is: MARAGU GmbH Seinsheimstrasse 9 D-97209 Veitshoechheim, Germany I have attached pictures of the left and right side views of the engine as well as the company flyer. I asked the question whether the engine would be sold in the US. This is the answer I got below: From: info@eco-motors.com To: "Keith Olivier" <classified> CC: "Martin Stürzenberger" <martin.stuerzenberger@schaeffler.com> Subject: RE: 80 & 100hp aviation turbo diesel engines Date: Tue, 11 Dec 2007 22:53:27 +0100 Hello Mr. Keith, Yes we are also convinced, that our engine class ideally fits to the LSA class within the US. To be clear, yes we also deliver the engines to the US, but for liability reasons, we have to make clear to the customers, that our engines are not certified aircraft engines. Before buying the engine, the customer has to sign and send back a document, where he confirms and accepts this non certified state explicitly. Would be nice to hear from you again Best regards Dr. Rainer Hirn Quote Link to comment Share on other sites More sharing options...
