Brent Parsley Posted November 26, 2005 Share Posted November 26, 2005 If not, I think you may want to check out Contego's intumescent "Fire Barrier" latex paint. As a new member I'm excited about the many benefits this product brings to this forum, and the protection it will provide you and your aircraft in case the unthinkable happens. Contego has some amazing capabilities that you might be interested in knowing more about at contegointernational.com. Recently an aircraft restoration company inquired about this intumescent paint and about its fire protection capabilities for the engine cowlings and firewalls on an older Albatross Coast Guard aircraft. Other pilots are finding out about it and using it everyday. The FAA is testing this product and several major carriers are either using it or planning to use it for firewall protection, cargo and baggage areas, and containers. One major manufacturer is using it on one of their big hangers and a well known internet aircraft supply company will be putting it on their web site in the near future. From the testing results below I think you will see why Contego is becoming more popular everyday in the fire safety industry. Contego Aluminum Sheet Test Procedure Test Panel 14"x14"x1/8" aluminum sheet Thermal Couples Thermal Couples (TC) 2,3 and 4 firmly fixed to cool side of aluminum panel in centered 6" circle to measure temperature of panel. TC 6 suspended on heat side of panel, tight to panel, directly in front of heat source to measure heat applied to surface of panel. Heat Source 250,000 BTU propane flame applied directly to surface of panel. Treated Panel One coat of red oxide primer followed by three spray coats of Contego intumescent latex paint, approximate coating thickness of 21mil. Results Untreated (bare) panel was completely destroyed in under 18 minutes with gradual temperature increase as noted in graph on web page. Treated panel had heat applied as noted in graph under identical setup as untreated panel. Test was conducted for 2 hrs and 15 minutes at which point it was discontinued. Contego International Inc. and the FAA are discussing the viability of using our paint to give added fire protection to all air cargo areas and containers on freight and passenger airlines. It has also been successfully tested and approved for use on the fiberglass fuel tanks of the V-22 Osprey. I have done burn tests on .025 aluminum flashing using Contego "Fire Barrier" Latex paint and MAPP gas which burns at 5340 F, on the unpainted portion it will burn through in 6 to 8 seconds. On the painted side with less than the recommended coating it has burned for almost an hour with NO DAMAGE to the surface of the metal or discoloration on the back side. I’ve had infra-red temperature readings on the back of the painted piece during the test and the temperatures ranged from 95-99 C which totally surprised everyone. Contego is tested and rated as a Class A fire stopper on wood, fiberglass, aluminum, steel, polyurethane foam and steel. If this information is of interest please call me so we can discuss it further. Brent Parsley West Sacramento, California 95691 Cell Ph. 916-718-8190 Off. Fax 916-376-0709 brentparsley@charter.net contegointernational.com “It is unwise to pay too much, but it is worse to pay too little. When you pay too much, you lose a little money—that is all. When you pay too little you sometimes lose everything because the thing you bought was incapable of doing the thing it was bought to do ... If you deal with the lowest bidder, it is well to add something for the risk you run, and if you do that you will have enough to pay for something better.” — John Ruskin (1819-1900) Quote Link to comment Share on other sites More sharing options...
