Maverick Posted January 26, 2005 Share Posted January 26, 2005 I am building a wind tunnel for a science fair project. can anyone help me out? Quote Link to comment Share on other sites More sharing options...
Len Evansic Posted January 26, 2005 Share Posted January 26, 2005 How big do you intend to make it, and what do you hope to discover with it? Since you are doing this for a science fair project, I assume that you would want to have it sitting at your booth. A small size like this wouldn't be conducive to collecting good data, as the entire tunnel would be too small to get laminar flow. If you want to measure things like lift or drag forces for an airfoil at various angles of attack, you may be better off making a water tunnel instead. This requires a good bit of math to translate between the viscosity of water to the viscosity of air, but will be easier to make and control accurately on a student budget. If you are just going for a "this is how an airfoil works" type of setup where you don't actually care about the forces of lift and drag, then a wind tunnel will be easier and cheaper to make. -- Len Quote -- Len Evansic, Cozy Mk. IV Plans #1283 Do you need a Flightline Chair, or other embroidered aviation accessory? Link to comment Share on other sites More sharing options...
Snoopy Posted January 31, 2005 Share Posted January 31, 2005 You might contact this gentleman: Robert Baals NASA Langley Research Center MS 464 Hampton, Va. 23681-0001 Some years ago he sent me some information and plans for a 7 X 10 inch wind tunnel. It is small enough to fit on a table and fairly simple to build, though some of the parts necessary for taking measurements would require some machine work. I hope this is of some help. Jim Quote Life is much too Important to be taken Seriously Link to comment Share on other sites More sharing options...
