Guest Guest Flyboy Posted July 6, 2002 Share Posted July 6, 2002 For Nat Puffer: Dear Tim, The ratio by weight (using a balance) is different than the ratio by volume (metering pump). If in doubt, use that ratios on the cans. Best regards, Nat PS: We are on the road, so I can't verify what my cans say, or the catalog either, for that matter. ---------- From: Tim, Jodi, & Cyrus MGS containers and spec. sheets say L285 is mixed 100:40 by weight. In Aircraft Spruce's 2001-2002 catalog, page 35, it says 100:43. Huh? Are they on that new fangled metric system or something. Quote Link to comment Share on other sites More sharing options...
unick3 Posted July 9, 2002 Share Posted July 9, 2002 For Andy: The information on the MGS web pages is as follows; L285 Volume - 100:50 Weight - 100:40 L335 Volume - 100:45 Weight - 100:38 All of the above with a tolerance of +/- 2 parts. Go to http://www.mgs-online.com/english/frames.htm and follow the link for techinical information, Registered laminating resin systems. Andy Richardson Cozy MkIV #911 Chapter 4 Quote Regards, Nick ___________________________________ Charleston, SC LongEZ, N29TM, 2400 hrs http://www.canardzone.com/members/nickugolini/ Link to comment Share on other sites More sharing options...
