First Flight: Cozy MKIV Plans #656
After 9 years of building, mostly one full day per week, Cozy MKIV plans #656 took to the sky for the first time. The maiden flight was made by owner Thane Ostroth on 6/21/08 from Pontiac Oakland Airport here in Michigan. It was an uneventfull flight according to Thane. Cylinder #2 temps dropped slowly and pretty much stopped firing after climb out and the pitch trim decided to stop working also. The problem with cylinder #2 turned out to be a clogged fuel injector (Superior IO-360) and the pitch trim (Strong) is binding up. 2.5 hours so far into Phase 1 flight testing and we work on the problems as they come up.
Bravo! Great to see your posts over the last couple years! :carrot::brocolli::banana: Toasting your success with a little V8 libation!!
Self confessed Wingnut.
Get up off that couch!!! =)
